cncah
Roundup Function?
Is there a function to round UP a decimal to the nearest integer?
I am in need of rounding numbers like 1.415 to 2, 3.46 to 4, etc.
Any help with getting my G-Code more accurate would be greatly appreciated. Thanks.
First add 0.50, and then do the normal round.
MP has a round( ) function, but I don't see any way to ensure you're always rounding up.   There is also the rounding method in the format statement, but based on the definition below I don't think it will help you
Rounding method. Use the following values:
  • (omitted) - Normal rounding.
  • 2 - Round final decimal to nearest even number.
  • 5 - Round final decimal to nearest multiple of 5.
  • 9 - Truncate the decimal portion of the value at the specified number of digits.
Below is an example that should round the passed in value up (or down), but I can't test it.  Maybe it will help you.
[email protected]    : 1
[email protected]  : 2
[email protected] : -99999
value      : 0
type       : [email protected]
int_value  : 0
frac_value : 0
#//The first argument is being passed by reference '!'
#//'type' is initialized to [email protected](1) and set to [email protected](1) at the end of 'pround'
#//Because of this, we can consider 'type' optional
pround(!value, type)
    #//Get the integer portion of the passed in value
    int_value = int(value)
    #//Get the fractional portion of the passed in value
    #//The fractional portion is not used in this example
    frac_value = frac(value)
     if type = [email protected],
        value = int_value + 1
        value = abs_value
    else,
        value = [email protected]
#//Calling example
#//Output (depending on format) ->
#//        x_abs is             : 4.75342
#//        x_abs rounded up is  : 5
#//        x_abs rounded down is: 4
x_abs : 0
y_abs : 0
z_abs : 0
pany_postblock
    x$ = 4.75342
    x_abs = vequ(x$)
    "x_abs is             :", *x_abs, e$
    pround(!x_abs, [email protected])
    "x_abs rounded up is  :", *x_abs, e$
    x_abs = vequ(x$)
    "x_abs rounded down is:", *x_abs, e$
    *e$
    #//The 'type' argument is optional
    x_abs = vequ(x$)
    pround(!x_abs)
I was close, but not correct:    2.0 + 0.5 = 2.5, will be round to 3.0
So first check for already being an integer.
then add 0.5 and round.
In macros we can use the FUP (fix up) function. Not sure if that will work for you in the post processor.
Thanks for the replies. The problem is not knowing which way to round.
I appreciate the example on how to use a function Jeff.
I will do something similar with a bunch of if statements to get the output I need.
I found an error in the code snippet I posted previously, a corrected version is below.
value      : 0
int_value  : 0
frac_value : 0
	else, if type = [email protected],
		value = abs_value
	else,
#//Calling example
x_abs : 0
y_abs : 0
z_abs : 0
pany_postblock
    x$ = 4.75342
    x_abs = vequ(x$)
    x_abs = vequ(x$)
    pround(!x_abs, DO[email protected])
    *e$
    x_abs = vequ(x$)
    pround(!x_abs)
  It's also worth noting that this example will only work for positive numbers.  It would need to be modified to round positive and negative numbers correctly.
