Incremental depth warning sign
Good morning everyone,
   I am trying to write a warning message if I choose DEPTH as INCREMENTAL because sometimes I make mistake instead of ABSOLUTE.  I wrote a logic warning for it and it didn't work well.  Would you guys tell me what I've done wrong?
PS: I did check on the parameter PDF file and it is 15103 but not sure why didn't work.
Thank you.
#Misc variables
IncAbsOperationDepth : no$ # Operation full depth
#Region sIncAbsOperationDepth
sIncAbsOperationDepth = "CUT#"+sToolPathNumber+" * Careful, you have INCREMENTAL DEPTH"
                        +no2asc(13)+"TOOL#"+no2str(t$)+" ("+s20001+")"
                        +no2asc(13)
                        +no2asc(13)+"Confirm LINKING PARAMETERS PAGE"
                        +no2asc(13)+"Your INCREMENTAL DEPTH value is= "+no2str(operation_depth)
                        +no2asc(13)+"Your the Z final DEPTH value is= "+no2str(operation_depth+OpTopOfStock)
                        +no2asc(13)
                        +no2asc(13)
                        +no2asc(13)+"                                               OK to proceed posting."
                        +no2asc(13)+"                                               CANCEL to abort posting."
#EndRegion sIncAbsOperationDepth
# Home Position Movement
fmt ""  4 IncAbsOperationDepth
# Rotation direction calculation
ptlchg_errorpop #Pop-up common toolchange errors
if IncAbsOperationDepth = 1 & opcode$ <2, [if mprint(sIncAbsOperationDepth, 2) = 2, exitpost$]
pparameter$ # Run parameter table
if prmcode$ = 15103, IncAbsOperationDepth = rpar(sparameter$, 1) #Check on INCREMENTAL DEPTH
opcode$ <2
Your 'opcode$ is equal to 1 or 2 , when processing a contour. ( 1 = 2D Contour, 2 = 3D Contour)
Thank you Colin.  How do I excluded all 3D toolpaths, should I use OPCODE or OPID?
Thank you for your help.
You can also set up a multi-check as shown below.
is_drilling_op =
      tool_op$ = 2 |
      tool_op$ = 475 |
      tool_op$ = 37 |
      tool_op$ = 104 |
      tool_op$ = 136 |
      tool_op$ = 306
is_drilling_op will be set to yes$(1) if a condition in the rounded brackets is true.
For this to work, newglobal$ must be set to 1.
20 hours ago, Colin Gilchrist said:
      if tool_op$ = 3 |
         tool_op$ = 5 |
         tool_op$ = 37 |
         tool_op$ = 201,
           # do something]
         else,
          # do something else
If you want more "types", just add a condition 'tool_op$ = xxx |' (notice the pipe symbol is the OR condition.
Thank you Colin, big help from you.
is_drilling_op =
      tool_op$ = 2 |
      tool_op$ = 475 |
      tool_op$ = 37 |
      tool_op$ = 104 |
      tool_op$ = 136 |
      tool_op$ = 306
Thank you Jeff, great input for me to learn.
