INVALID ARC
Hello everyone,
   Once in a while it gives me INVALID ARC although the codes are OK, can you guys tell me what I might done wrong with the source file in CIRCLE MILL?
Thank you..
02 Oct 2019 03:12:50 PM - Post processor execution initialized.
02 Oct 2019 03:12:50 PM - Unencrypted input file:
02 Oct 2019 03:12:50 PM - D:\Users\Public\Documents\Shared Mastercam 2020\mill\Posts\Vertical Horizontal Index.pst
02 Oct 2019 03:12:50 PM - Loading input files was successful.
02 Oct 2019 03:12:51 PM - Initialization of pre-defined post variables, strings, postblocks was successful.
02 Oct 2019 03:12:51 PM - Search for defined post variables, strings, postblocks was successful.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(230), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(360), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(548), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(678), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(866), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(996), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1184), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1314), OPID(18)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1410), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1450), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1548), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1588), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1686), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1726), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1824), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - RUN TIME -NCI(1864), OPID(22)- An invalid full arc was detected. The arc is converted to a single linear move to avoid gouging, contact your reseller.
02 Oct 2019 03:12:52 PM - Successful completion of post processor execution.
21 hours ago, Leon82 said:
You are attempting to spring pass with an overlap on lead in. You have to turn off overlap when using spring pass
Hello Leon82,
   It worked, however I want to use this overlap on the CIRCLE MILL. is there away we can by pass this?
Thank you.
