JParis 212
Harvey Tool lives in this realm
4
jeff 1,910
thank you gentlemen
peter ~ 30
1 hour ago, Joeyls319 said:Hello all
Does anyone out there have any recommendations where to get micro tooling, more specifically a .5mm endmill?
I need to look at other suppliers to try out. The ones we use now don't last very long.
We are cutting at 66,500 rpm in .5mm thick titanium.
Thanks ahead of time
Joey
To increase your tool life I would suggest a ramp entry if you are not already doing so, vertical entry can damage your tool right off the get-go.Also avoid presetting with a probe if you can or use a reduced feedrate if that applies to you.As for supplier microcut is a good brand. I think the website is microcutusa.com
Thanks Peter
Im already ramping and we are using a laser to touch off the tool. I will
have to check out the website you posted.
thanks again
1
nickbe10 198
15 hours ago, Joeyls319 said:thank you gentlemen
Mikron make some small endmills. Their small drills are outstanding.
1
gcode 10,017
No experience with 65K rpm in TI, but Harvey Tool rocks
1
Sticky 587
When you get this small I actually think Harvey Tool sucks, their run out and diameter tolerance in this range is going to give you grief. Not that I dislike Harvey Tool at, but when you get into cutters under 1mm, everything gets a lot more important, really quick. Union Tool is usually my go to for this type of stuff - not the best, but still very good, and pretty affordable for what you are getting.
MIL-TFP-41 640
^^^^These guys have tiny stuff
Richards Micro Tool either makes or used to make all of the harvey miniature series. Good stuff. https://www.richardsmicrotool.com/
Kyocera is also very good at the small stuff. http://www.kyoceramicrotools.com/micro/milling/square-end.html
2
Rstewart 657
Looking through that PMT site, they have sub .001" endmills. .001" and up actually have a square end cut.
How do you generate enough rip-em's to use a .001" endmill????
Tim Johnson 470
gcode 10,017
On 10/24/2019 at 9:27 AM, MIL-TFP-41 said:Richards Micro Tool either makes or used to make all of the harvey miniature series
Someone at a trade show once told me that Harvey doesn't actually make anything
The are just brokers selling other peoples products
I do not know if that is true.
There are becoming a presence in the industry though having gobbled up Helical and Micro100 recently
Tim Johnson 470
There's a grind shop in Kalamazoo MI That does work for Harvey.
Redfire427 75
Hitachi would be my first choice followed by OSG. Both pricey, but Hitachi endmills are simply the best I have ever used.
Carmen
Recently Browsing 0 members
Hello all
Joey
