Active report output a pop up message
On 12/7/2019 at 4:31 PM, peter ~ said:
If anyone else could also tell me if this is working properly I would appreciate it so much.
Peter here is what happened when I tried to fire up Mastercam. Might need to check your resource mapping in your .dlls and make sure you not mapping across your local network or some other network with your .dll files. I have seen this problem many years ago and where being able to test on a stand alone system is usually best to debug these types of issues.
I did have to trust both the .dll files through Norton since they have to reputation, but that is not related what I am seeing about.
Thank you, I think I need to link in the 2020 NETHOOK_3.dll
54 minutes ago, peter ~ said:
The resources should be okay,it loaded fine in 2018
Peter, are you checking this on a stand a lone system not hooked up to your network or other local resources you have on the computer your testing with? Not sure if you have a off network laptop or system that has Mastercam installed but trying running it on that and see if everything works. If it does still doesn't mean you have covered everything still may need to build and test on a 2020 system.
If you right click properties -> attributes -> unblock it will work
Peter that worked to run Mastercam, but I am not sure how or what your work flow intent is for this Chook. I tried it on one of my Mill/Turn projects I am currently programming and it crashed Mastercam. Not sure since everything is define and correct not sure what good my test does, but I got it loaded and on the QAT. Might think about designing a Logo for your .dll so when it is run someone knows what it is verses the Mastercam M that comes in as the default for all no logo Chooks. Maybe Steven can chime back in and see if it s doing everything he needs. Keep plugging away and help solve problems. :thumbsup:
Yes I will do a logo, and add in 2020 version of nethook_3!! thank you
On 12/7/2019 at 2:46 PM, peter ~ said:
This  c++ example for mastercam 2018 successfully handles operations with "common parameters" (CONTOUR,DRILLING,2D DYNAMIC MILL,AREA MILL,POCKET)
#pragma once
//api_tools_exp.h
#include "Header.h"
//functions 1:
  ///mastercam stuff :D
void Get_Tool_From_Op(tp_tool &tl, operation &op)
	op_group * machine = OMgetActiveMachineGroup();
	tl_list *nu_t_tlist, *cur_t_tlist;
	DB_LIST_ENT_PTR t_ptr, o_ptr;
	bool t_succf, o_init_ret;
	nu_t_tlist;
	char szLibName[255] = "";
	void * list_ptr = NULL;
	list_manager(TL_ID, szLibName, LSTMGR_GET, &list_ptr);
	nu_t_tlist = (tl_list*)list_ptr;
	if (nu_t_tlist != NULL)
		cur_t_tlist = nu_t_tlist;
		while (cur_t_tlist != NULL)
			if (op.tl.slot == cur_t_tlist->tl.op.slot)
				tl = cur_t_tlist->tl;
				break;
			cur_t_tlist = cur_t_tlist->next_ptr;
		operation_manager(&op, OPMGR_REWRITE, &o_ptr, &o_init_ret);//rewrite operation
//class to export:
class ExportFunctions
public:
	int LoopThroughOperations(double a, double b, int c, int d)
		op_list *nu_o_oplist, *cur_o_oplist;
		bool t_succf = true, o_init_ret;
		list_manager(OP_ID, szLibName, LSTMGR_GET, &list_ptr);
		nu_o_oplist = (op_list*)list_ptr;
		if (nu_o_oplist != NULL)
			cur_o_oplist = nu_o_oplist;
			while (cur_o_oplist != NULL)
				tp_tool tl;
				DB_LIST_ENT_PTR* tlptr;
				Get_Tool_From_Op(tl, cur_o_oplist->op);
				char message[2000];
				sprintf_s(message, " # : %lf : %lf", cur_o_oplist->op.cmn.depth, tl.oa_length);
				MessageBox(NULL, t_succf ? message : "Operation Failed", "SharkBait", MB_OK);
				if (cur_o_oplist->op.cmn.depth < 0.0 - tl.oa_length) {MessageBox(0, "Error Z-Depth Is Greater Than Overall Tool Length", "ERROR",MB_OK); }
				if (tl.oa_length + cur_o_oplist->op.cmn.depth > .5) { MessageBox(0, "Error Overall Tool Length Is Greater Than 0.5", "ERROR", MB_OK); }
			if (cur_o_oplist->op.db.select_flag == FALSE)
				bool succf = FALSE;
				DB_LIST_ENT_PTR eptr;
				cur_o_oplist->op.db.select_flag = TRUE;
				operation_manager(&cur_o_oplist->op, OPMGR_REWRITE, &eptr, &succf);
			/* next operation */
			cur_o_oplist = cur_o_oplist->next_ptr;
		return 1;
Hello Peter,
   Are these codes can be added to my current Active Report file?
Thank you for your time,
   S.Luong
13 minutes ago, PcRobotic said:
Hello Peter,
   S.Luong
No, for active reports the code is always written in the vb.net editor.
#pragma once
//api_tools_exp.h
#include "Header.h"
//functions 1:
	nu_t_tlist;
				break;
//class to export:
public:
				tp_tool tl;
				char message[2000];
				bool succf = FALSE;
		return 1;
Good morning Peter,
    Thank you for your valuable time and great amount of hard coding.  My question is, are these hard codes are for active report for C-Hook?  If Active Report, how can I embed it into my current Active Report when I already used VIRTUAL BASIC language.
Once again, thank you for your time.
8 minutes ago, PcRobotic said:
Good morning Peter,
They are for CHOOK
