Custom Setup Sheet Data from NC FILE C# :
On 12/18/2019 at 5:30 AM, content creator said:
I wasn't trying to give that impression 😕 I want to learn..I was just giving my point of view, anyway thanks for your comments.. good luck to you.
I wasn't trying to be short; you just seem to be in a "I need this to work" situation and not a "I need this to work AND be maintainable, well organized, etc." situation.  Take everything you read below with a grain of salt; I'm largely self-taught and this is not my field of expertise.
Anyway, I took a look at your code over the holiday break.  At this point I only have a few of your functions refactored; if time allows I’ll do more.
I made this a CLI/CLR project with a WPF interface so I could quickly test everything.  I also moved to a more traditional project layout with definitions in the header files and implementations in the source files.
The first thing I noticed is that you have two functions that do almost the same thing; BlankAllNonSolidEnts and UnBlankAllNonSolidEnts.  I merged BlankAllNonSolidEnts and UnBlankAllNonSolidEnts into one method BlankUnblankAllNonSolids.
int APIToolsNative::APITools::BlankUnblankAllNonSolids(bool unblank)
	int numberOfEntitesModified = 0;
	auto entityPointer = db_start;
	while (entityPointer != nullptr)
		if (entityPointer->eptr->id != SOLID_ID)
			numberOfEntitesModified++;
			if (unblank)
				sel_bit_turn_off(entityPointer->eptr, BLANK_BIT);
				entityPointer->eptr->color = MC_RED;
			else
				sel_bit_turn_on(entityPointer->eptr, BLANK_BIT);
			write_ent_sel(entityPointer->eptr, entityPointer->eptr->eptr);
		entityPointer = entityPointer->next;
	if (numberOfEntitesModified > 0)
		repaint_graphics();
	return numberOfEntitesModified;
In addition to combining the functions, I went with a while loop to traverse the linked list.
You can review everything I’ve done on my GitHub
Hope that helps.
Accurate.
I am hoping to improve in the future, since I don't necessarily need to write much new code,
I'll check it out, thank you!
I started working on your BreakSplines function and the following condition jumped out at me.
	if (entity.id == S_ID || entity.id == NB_ID)
This is unnecessary; S_ID and NB_ID are binary so we can use the bitwise operators and simplify things.
	if (entity.id & (S_ID | NB_ID))
Or, we can just use the SPLINE_ID definition from BaseDefines_CH.h
#define SPLINE_ID	(S_ID | NB_ID)	//!< Spline:  parametric or NURBS
	if (entity.id & SPLINE_ID)
^ This is good. I like what you've done so far I had more time to look over it carefully, the refactored functions look like they may provide more efficiency and are very clear to read. :D
3 minutes ago, Zaffin said:
Yes?
        public int CreateSilhouetteBoundary()
            using (var apiTools = new APIToolsNative.APITools())
                return apiTools.CreateSilhouetteBoundary();
Thanks, I think I may see what I was doing wrong, I'm writing mostly operations function right in c++/cli I can show you if you like. I've been trying to only use the ".net stuff" as much as possible.
Very rough early version of the functions
int makendmil(int tlnum,double tooldia,double feedrate,int rpm,System::String ^ Name)
	Mastercam::Tools::EndMillFlatTool tool;
	tool.Diameter = tooldia;
	tool.Feed = feedrate;
	tool.Length = 2.0;
	tool.FluteLength = 0.75;
	tool.Flutes = 4;
	tool.MfgToolCode = "Code : ";
	tool.TipAngle = 180.0;
	tool.PlungeFeed = 75.0;
	tool.DiameterOffset = tlnum;
	tool.LengthOffset = tlnum;
	tool.Number = tlnum;
	tool.Name = Name;
	tool.SpindleRotation = 0;
	tool.RadiusType = Mastercam::Database::Types::ToolRadiusType::None;
	tool.RPM = rpm;
	tool.RetractFeed = 500.0;
	tool.ShoulderDia = tooldia;
	tool.ShankDia = tooldia;
	tool.ShoulderLength = 1;
	tool.IsMetric = false;
	tool.Coolant = Mastercam::Database::Types::CoolantMode::COOL_OFF;
	return tool.Commit() ? tool.Slot : 0;
int makecsopfromchains(int level, double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId,
	Mastercam::Operations::Types::ContourSubtypeType cntrtpe, Mastercam::Database::Types::CutterCompDir cuttercompdir,
	Mastercam::Database::Types::ChainDirectionType chndir, int FeedRate, int spindlespeed, bool tabison,int slot,bool osciateison)//, EndMillFlatTool ^ tool)
	auto views = Mastercam::Support::SearchManager::GetViews();
	Mastercam::IO::ViewManager::GraphicsView = views[viewId];
	Mastercam::IO::ViewManager::CPlane = views[viewId];
	Mastercam::IO::ViewManager::TPlane = views[viewId];
	Mastercam::Database::ChainManager::ChainTolerance = .015;
	const auto chains = Mastercam::Database::ChainManager::ChainAll(false, false, nullptr, chndir, level);
	//check that we have something///////////////////////////////////////////////////////////////////////////////////////////////////
	//System::Windows::Forms::MessageBox::Show("chk");
	if (chains != nullptr && chains->Length != 0)
		auto cntrop = gcnew Mastercam::Operations::ContourOperation;
		cntrop->AssignMillToolBySlot(slot);
		cntrop->UpdateToolSettings();
		cntrop->CutterComp.Direction = cuttercompdir;
		cntrop->CutterComp.RollCorners = Mastercam::Database::Types::CutterCompRoll::CutterCompRollAll;
		//linking params
		cntrop->Linking->FeedPlane = feedPlane;
		cntrop->DepthCuts.Enabled = true;
		cntrop->DepthCuts.CutOrderByDepth = true;
		cntrop->DepthCuts.FinishNumberCuts = 0;
		cntrop->DepthCuts.MaxRoughStep = .755;
		cntrop->DepthCuts.TaperedWalls = false;
		cntrop->DepthCuts.UseSubprogram = false;
		cntrop->Linking->Depth = depth;
		cntrop->Linking->ClearanceOn = true;
		cntrop->Linking->Clearance = clearancePlane;
		cntrop->Linking->Retract = clearancePlane;
		cntrop->Linking->RetractOn = true;
		cntrop->Linking->TopStock = topOfStock;
		cntrop->MiscValues->UseValuesFromPost = true;
		cntrop->MultiPass.Enabled = false;
		if (tabison)
			cntrop->Tabs.AutomaticPosition = true;
			cntrop->Tabs.TabAll = true;
			cntrop->Tabs.Enabled = true;
			cntrop->Tabs.AutoTabByDistance = false;
			cntrop->Tabs.NumberOfTabs = 4;
			cntrop->Tabs.EntryExitMode = Mastercam::Operations::Types::TabEntryExitType::Vertical;
			cntrop->Tabs.TabThickness = 0.04;
			cntrop->Tabs.TabWidth = 0.1;
		if (!tabison)
			cntrop->Tabs.Enabled = false;
		if (osciateison)
				if (topOfStock <= .25)
					cntrop->Linking->Depth = topOfStock;
					cntrop->Oscillate.MaximumDepth = 0.035 - topOfStock;
			if (topOfStock <= .755 && topOfStock > .25)
				cntrop->Linking->Depth = topOfStock - .05;
				cntrop->Oscillate.MaximumDepth = 0.085 - topOfStock;
			if (topOfStock > .755)
				cntrop->Linking->Depth = topOfStock - .25;
				cntrop->Oscillate.MaximumDepth = -.5;
			cntrop->Oscillate.OscillationDistance = 4.0;
			cntrop->Oscillate.MovementType = Mastercam::Operations::Types::OscillationMovementType::Highspeed;
		cntrop->ForceToolChangeOn = false;
		cntrop->BreakThrough.Enabled = false;
		cntrop->ArcFilter.Enabled = false;
		cntrop->RotaryAxis.Enabled = false;
		cntrop->CutParams.ContourSubtype = cntrtpe;
		cntrop->CutParams.InternalCornerRoundingRadius = .001;
		cntrop->PlungeRate = 75.0;
		cntrop->RetractRate = 500.0;
		//lead in
		//entry params
		cntrop->Entry.ArcRadius = .025;
		cntrop->Entry.ArcSweep = 90.0;
		cntrop->Entry.HelixHeight = 0.0;
		cntrop->Entry.Enabled = true;
		//end lead in
		cntrop->SpindleSpeed = spindlespeed;
		//set feedrate
		cntrop->FeedRate = FeedRate;
		cntrop->NCIName = "Contour #1";
		cntrop->Name = "Contour operation created via API";
		operation op = {};
		DB_LIST_ENT_PTR ptr;
		bool succf;
		cntrop->SetChainArray(chains);
		if (!cntrop->Commit())
			return 0;
		op.op_idn = cntrop->GetOperationID();
		operation_manager(&op, OPMGR_GET, &ptr, &succf);
		op.u.prm_cntr.ex_corner_rad = 0.001;
		op.cmn.stk_remain = 0.0;
		op.dcuts.stock_t_l = 0.0;
		operation_manager(&op, OPMGR_REWRITE, &ptr, &succf);
		operation_manager(&op, OPMGR_NCI_REGEN, &ptr, &succf);
	return 1;
int makecspktopfromchains(int level, double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId,
	Mastercam::Database::Types::ChainDirectionType chndir, int FeedRate, int spindlespeed, bool tabison, int slot, bool osciateison)//, EndMillFlatTool ^ tool)
	const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, views[viewId], chndir, level);
	operation op = {};
		auto cntrop = gcnew Mastercam::Operations::PocketOperation;
		cntrop->Roughing.Enabled = true;
		cntrop->Finishing.Enabled = false;
		//linking params
		cntrop->PocketRoughEntry.Helix.MaxRadius = .2;
		cntrop->PocketRoughEntry.Helix.MinRadius = .05;
		cntrop->PocketRoughEntry.Helix.ClearanceXY = .05;
		cntrop->PocketRoughEntry.Helix.ClearanceZ = .05;
		//cntrop->PocketRoughEntry.EntryMode
		cntrop->DepthCuts.UseIslandDepths = false;
		//lead in
		//entry params
		//end lead in
		//set feedrate
		cntrop->NCIName = "Pocket #1";
		cntrop->Name = "Pocket operation created via API";
			return 0;
		DB_LIST_ENT_PTR ptr{};
		bool succf{};
		op.u.prm_pkt.add_finish = false;
		op.u.prm_pkt.climb = false;
		op.u.prm_pkt.taper.on = false;
		op.u.prm_pkt.rough = true;
		op.u.prm_pkt.ch_sort.sort_method = 1;
		op.u.prm_pkt.co_spir_disp = true;
		op.u.prm_pkt.add_finish = true;
		op.u.prm_pkt.rgh_step_pct = 50;
		op.u.prm_pkt.rgh_entry.on = true;
		op.u.prm_pkt.rgh_entry.entry_type = 0;
		op.u.prm_pkt.rgh_entry.helix.angle = TWO_PI / 36;
		op.u.prm_pkt.rgh_entry.helix.z_clear = .05;
		double min = .05, max = .5;
		op.u.prm_pkt.rgh_entry.helix.rad_min = min;
		op.u.prm_pkt.rgh_entry.helix.rad_max = max;
		op.u.prm_pkt.rgh_entry.helix.xy_clear = .05;
		short stk_mde = 2;
		short cut_mthd = 2;
		op.u.prm_pkt.cp.cmp_to_tip;
		double dbl = .005;
		op.u.prm_pkt.cp.lin_tol = dbl;
		op.u.prm_pkt.cut_method = cut_mthd;
		op.u.prm_pkt.tool_down = true;
		short pck_typ = 0;
		op.dcuts.tool_down = true;
		op.u.prm_pkt.pock_type = pck_typ;
		op.u.prm_pkt.finish = false;
		op.u.prm_pkt.spiral_out = true;
		op.u.prm_pkt.rgh_step_pct_flat = true;
	return 1;
		if (tabison)
		if (!tabison)
Sorry, this just struck me funny!
I only want to write C++ when I have to; I'd much rather handle everything in C# and create a native .dll only if needed.  This is likely because I know nothing about MFC so any interface I create will be WPF.
How come? :p
I can show you how to setup an easy ui using the win32 api if you like, I have some projects kicking around. MFC is too much IMO. Very time consuming to learn and manipulate.
#include <windows.h>
// Globals
#define ID_FILE_EXIT 1001
// Functions
// Name: WindowProc()
// Desc: The window message procedure.
// Name: WinMain()
// Desc: Application entry point. Creates several windows
//       and adds them to the docking system.
int main()
	HINSTANCE hInstance{}; HINSTANCE hPrevInstance{}; LPSTR lpCmdLine{}; int nShowCmd{};
	WNDCLASSEX wc,wc2;
	RECT rc;
	MSG msg;
	// Create the windows
	//Setup the window class
	wc.cbClsExtra = 0;
	wc.cbSize = sizeof(WNDCLASSEX);
	wc.cbWndExtra = 0;
	wc.hbrBackground = CreateSolidBrush(GetSysColor(COLOR_BTNFACE));
	wc.hCursor = LoadCursor(0, IDC_ARROW);
	wc.hIcon = LoadIcon(GetModuleHandle(0), IDI_APPLICATION);
	wc.hIconSm = LoadIcon(GetModuleHandle(0), IDI_APPLICATION);
	wc.hInstance = GetModuleHandle(0);
	wc.lpfnWndProc = DefWindowProc;
	wc.lpszClassName = "DOCKINGWINDOW";
	wc.lpszMenuName = 0;
	wc.style = CS_HREDRAW | CS_VREDRAW;
	//Register the window class
	if (!RegisterClassEx(&wc))
		//Error
		return 0;
	auto gParent = CreateWindowEx(0, "DOCKINGWINDOW", "Parent Window", WS_OVERLAPPED | WS_SYSMENU | WS_VISIBLE, (GetSystemMetrics(SM_CXSCREEN) / 2) - 150, (GetSystemMetrics(SM_CYSCREEN) / 2) - 150, 500, 500, 0, 0, hInstance, 0);
	if (gParent == 0)
		//Error
		return 0;
	HMENU hMenu, hSubMenu;
	hMenu = CreateMenu();
	hSubMenu = CreatePopupMenu();
	AppendMenu(hSubMenu, MF_STRING, ID_FILE_EXIT, "E&xit");
	AppendMenu(hMenu, MF_STRING | MF_POPUP, (UINT)hSubMenu, "&File");
	EnableMenuItem(GetSubMenu(GetMenu(gParent), 0), ID_FILE_EXIT, MF_DISABLED | MF_GRAYED);
	SetMenu(gParent, hMenu);
	UpdateWindow(gParent);
	// The message loop
	while (GetMessage(&msg, 0, 0, 0))
		if (msg.message == WM_COMMAND)
			if (LOWORD(msg.wParam) == ID_FILE_EXIT) {
				PostQuitMessage(0);
				return 0;
			//Post a quit message
		//commands
		TranslateMessage(&msg);
			DispatchMessage(&msg);
		//Return to windows
		return msg.wParam;
Just so you know this is the total process to create a window with a menu on it and tying a function to it.
I'm basically the opposite I can't do c#, the only stuff I do these days are a few c# scripts in unity for game stuff. c++ is my jam and if I need .net I stick to f#
On 12/17/2019 at 7:46 PM, Zaffin said:
you're also allocating memory on the heap and never freeing it; that's less than ideal.
Would it be possible for you to provide me an example of what you meant by this? I would like to improve.
Maybe?  Cpp isn't my jam, but I'll do my best.
Consider the below code...
#include <iostream>
#include <string>
#include <memory>
class Point
public:
	std::string Name;
	double X;
	double Y;
	Point();
	Point(std::string pointName, double xPosition, double yPosition);
	~Point();
Point::Point()
	Name = "Default Name";
	X = 0.0;
	Y = 0.0;
Point::Point(std::string pointName, double xPosition, double yPosition) : Name(pointName),  X(xPosition), Y(yPosition)
Point::~Point()
	std::cout << "Destructing " << Name << std::endl;
int main()
	/*Curly braces define scope;
	this will allow us to see what happends when the below objects go out of scope. */
	// A point object created on the stack.
	Point pointOne{ "Point One", 1.0, 1.0 };
	// A raw pointer created on the heap.
	auto pointTwo = new Point("Point Two", 2.0, 2.0);
	// A smart pointer.
	auto pointThree = std::make_unique<Point>("Point Three", 3.0, 3.0);
// Output:
//	Destructing Point Three
//	Destructing Point One
Did you notice that the destructor for pointTwo wasn't called?   Because it was created with the 'new' keyword, it's our responsibility to clean it up before it goes out of scope.
This issue can largely be avoided by using smart pointers; pointThree is an example of a smart pointer.
I suggest you check out google; there are many good videos on this subject.
#include <iostream>
#include <string>
#include <memory>
class Point
public:
	std::string Name;
	double X;
	double Y;
	Point();
	~Point();
Point::Point()
	X = 0.0;
	Y = 0.0;
Point::~Point()
int main()
	// A smart pointer.
// Output:
Thanks for the info.. I've been reading a lot about this,
right now I write everything in c++/cli project using various c# and c++ libraries.
I store the bulk of my data in vectors declared like
int get_size()
std::vector<int> vector_of_ints;
  int randomnumber = 1000;
 for(auto i = 0; i < randomnumber; i++;)
   vector_of_ints.push_back(i);
   //do something with the vector
   return i;
I guess that technically stores the data on the heap then it gets deallocated when the function goes out of scope, If I am understanding correctly would a vector be a good place to use a smart pointer, or would you recommend an array?
int get_size()
   return i;
Nope, that vector is on the stack;  it's lifetime is from declaration till it goes out of scope.  In the above example I see no reason to change anything.
I would not use a C-style array; I prefer the containers from the standard library.
36 minutes ago, Zaffin said:
Nope, that's a stack allocation, in the above example I see no reason to change anything.
This is where I read that the memory is actually allocated on the heap.
https://stackoverflow.com/questions/8036474/when-vectors-are-allocated-do-they-use-memory-on-the-heap-or-the-stack
I tried using the smart pointer in a project I am converting, not sure If I am doing this right :
	System::String^ data = "data";
		System::String^ nstlist = NETHookNesting::NestingConstants::NestListExampleFile;
	auto nestListFile = System::IO::Path::Combine(System::IO::Path::Combine(Mastercam::IO::SettingsManager::UserDirectory, data), nstlist );
	auto nestingDefaultsFile = System::IO::Path::Combine(Mastercam::IO::SettingsManager::SharedDirectory, Mastercam::IO::SettingsManager::Metric ? NETHookNesting::NestingConstants::MetricNestingDefaultsFile : NETHookNesting::NestingConstants::EnglishNestingDefaultsFile);
	auto NestingFile = std::make_unique<Mastercam::Nesting::NestingFile>(nestingDefaultsFile);
      // Create an instance from nesting defaults and clear out any existing parts and sheets
	array<Mastercam::Nesting::NestingPart^>^NestingPartArray;
	array<Mastercam::Nesting::NestingSheet^>^SheetArray;
	NestingFile->SheetArray = SheetArray;
	NestingFile->PartArray = NestingPartArray;
The vector is on the stack and the contents are on the heap.  You did not allocate the heap memory so you do not need to free it.  When the vector goes out of scope the memory will be freed.  I don't see a reason to worry about using a smart pointer in the above example.
I'm not sure what your trying to do in the above snippet, or what the issue is.
When you look at the Mastercam SDK remember that Mastercam is 35 years old.  Most of the newer functions seem to use the STL stuff.  Alot of MFC in there too.
