ecourses
nolongat
  • 1 month later...
not a response, a new question about:
tutorial #4 Review Exercise
In Mastercam 2019 Mill Essentials eCourse, my model is not working. it is not perfect as to the joints, i tried to do the wire work in by drawing only a quarter and then translating the rest which i think is causing other problems. Where is the problem?
https://www.evernote.com/l/ADJKqDKmdrZFfayflo1OJBo9dUav8Ads_bk/
From the picture, you have an incomplete chain.
Try creating a silhouette boundary geometry, or select create curve on all edges then select only the face mask. You could also just join the broken line in the wireframe. Or widen your chain tolerance (not recommended!!).
See the attached photos.
1)  Set your stock up correctly.
2) Re-draw your wire frame geometry correctly. On your file you have 24 duplicate lines and 42 duplicate arcs. Your wire frame geometry is also not correct, see the photo with my template in red over your's in blue.
3) After correcting your wire frame fix your solid to match the corrected geometry. Don't forget to add the chamfers on the solid.
4) Make a change on your 3rd toolpath in the Transition tab - skip pockets smaller than - it should be 100%
i wish i undersood. thanks though.
To use the silhouette boundary function ;
select the solid, then in the wireframe tab select silhouette boundary and press okay.
  • 3 weeks later...
