SavannahG
Define reduced neck tool with VB Net-Hook
I've searched and searched and I can not find a property in the Net-Hook API to define the reduced neck diameter and length for an end mill. There's flute, shank, and shoulder, but no reduced neck, Is this missing, or am I missing something?
If you are creating a t-slot type tool you could define the shoulder as the portion with the smaller diameter.Thats the one I use.
Have you looked at the ToolNetApi.dll that ships with the newer versions of Mastercam?
Thank you for the suggestions.
Peter, I'm trying to define a end mill with a relief diameter, so it goes cutter diameter/length, then shoulder diameter/length, then Neck diameter/length, then Shank diameter to Overall length.
Jeff, I'm going by the Net-Hook API reference guide online version of the NET-Hook_v3 Reference. That was what I found in the MasterCam downloads. I'll look into the ToolNetApi. It looks promising.
Jeff, do you have an example of how to save the tool to the tool manager using the ToolNetApi.dll functions? I have the method for the Mastercam.database EndMillFlatTool class as follows:
    Friend Function CreateEMFlat(P As Integer) As EndMillFlatTool
        ' Define a new tool
        Dim endMill = New EndMillFlatTool(ToolDia(P), ToolRad(P), ToolNum(P), ToolLenOff(P), ToolDiaOff(P), oa_len(P), flute_len(P), shldr_len(P), ToolCmnt(P)) With {
                    .Coolant = CoolantMode.COOL_FLOOD,
                    .Flutes = ToolFlts(P),
                    .MfgToolCode = ToolMfg(P),
                    .PlungeFeed = ToolPlunge(P),
                    .RetractFeed = ToolRetract(P)}
        MessageBox.Show("Neck Relief = " & ToolRel(P))
        ' Commit the tool to the database
        Return If(Not endMill.Commit(), Nothing, endMill)
    End Function
I've been trying to figure out how to commit the tool using the ToolNetAPI TlToolEndmill class.
    Friend Function CreateEMF(P As Integer) As TlToolEndmill
        ' Define a new tool
        Dim endMill = New TlToolEndmill() With {
                    .OverallDiameter = ToolDia(P),
                    .OverallLength = oa_len(P),
                    .ShoulderDiameter = shldr_len(P),
                    .ShoulderLength = shldr_len(P),
                    .NeckDiameter = ToolRel(P),
                    .Name = ToolName(P)}
        Return ???
    End Function
As SavannahG mentions, never versions of Mastercam has an extended API for working with tools and assemblies. I thought there was an example up on our website under the 3rd Party developers .NET developers section, you might want to check that out.
        ' Define a new tool
    End Function
        ' Define a new tool
        Return ???
    End Function
Look at the chainmanager example for vb.net Under downloads in the services folder there should be an example of the vb function with a return type did you try this :
        ' Define a new tool
        Return If(Not TlToolEndmill.Commit(), Nothing, TlToolEndmill)
    End Function
I'm allergic to VB.Net's syntax; below is a (very) basic c# example.
namespace ToolNetApiExample
    using Mastercam.App;
    using Mastercam.App.Types;
    using Cnc.Tool.Interop;
    public class Main : NetHook3App
        public override MCamReturn Run(int param)
            var toolSystem = TlToolFunctions.GetToolSystem();
            var endMill = new TlToolEndmill()
                Name = "Example .5in Reduced Shank Tool",
                OverallDiameter = .5,
                TruePhysicalLength = 4,
                CuttingDepth = .375,
                ShoulderLength = 2.0,
                ShoulderDiameter = .375,
                ArborDiameter = .5,
                IsMetric = false
            var toolAssembly = new TlAssembly()
                MainTool = endMill,
            toolSystem.Add(toolAssembly);
            return MCamReturn.NoErrors;
  • Haha 1
HOORAY! It works. Thanks Jeff. I spent hours digging through the sample code and never found an example addressing the tool manager using the ToolNetAPI. Your example is exactly what I needed. I just tweaked a few things for VB, and it works. Here's the VB  version, try not to sneeze!
        Dim toolSystem = TlToolFunctions.GetToolSystem()
        ' Define a new tool
                    .ShoulderDiameter = shldr_dia(P),
                    .NeckDiameter = rel_dia(P),
                    .Name = ToolCmnt(P),
                    .ToolNumber = ToolNum(P),
                    .FluteCount = ToolFlts(P),
                    .DiameterOffsetNum = ToolDiaOff(P),
                    .LengthOffsetNum = ToolLenOff(P),
                    .ShankType = shnk_type(P),
                    .TaperLength = rel_len(P)}
        Dim toolAssembly = New TlAssembly() With {.MainTool = endMill}
        Return If(Not toolSystem.Add(toolAssembly), Nothing, endMill)
    End Function
