Sign in to follow this
c++
CHOOK question : using "chains_overlap_pct"
Hi I am trying to determine the overlap percentage between 2 chains, however I keep getting a result of zero when I check the value. This is the relevant section of the code :
int SortSplines()
		std::vector<ent> spl1;
		std::vector<ent> spl2;
		sort_lines(1000, 500, spl1, spl2);
		std::vector<CHAIN*> chn1;
		std::vector<CHAIN*> chn2;
		for (auto spline : spl1)
			sel_bit_turn_on(&spline, SELECT_BIT);
			write_ent_sel(&spline, spline.eptr);
			auto chn = CreateChain(spline);
			chn1.push_back(chn);
		for (auto spline : spl2)
			chn2.push_back(chn);
		for (auto chain1 : chn1)
			for (auto chain2 : chn2)
				double pct1 = 2.0; double pct2 = 2.0;
				chains_overlap_pct(chain1, chain2, 0.005, &pct1, &pct2);
				auto ret = chains_intersect(chain1,chain2,.005);
				char message1[5000];
				bool allok1 = true;
				sprintf_s(message1, "x : %lf y: %lf ret : %d", pct1,pct2,ret);//2275712//2275680
				MessageBox(NULL, allok1 ? message1 : "Operation Failed", "SharkBait", MB_OK);
		return 1;
52 minutes ago, Roger Martin from CNC Software said:
What version of Mastercam ?
Sorry Roger, it is Mcam 2018.
The chains intersect returned a value but not the overlap
3 minutes ago, Roger Martin from CNC Software said:
Peter,
Is Mastercam in "Design" mode when executing - chains_overlap_pct (...) ?
You need to have at least a Machine Group so Mastercam is not in Design.
Otherwise it will always return 0 in the (2) out variables.
I will need to check. I will ensure the machine group is active while calling the function. Do you know if the chains_intersect function requires an active machine group?
7 minutes ago, Roger Martin from CNC Software said:
Yes, if there is no Machine Group(s), it will return '-1' (error).
When I ran the test chains_intersect returned 1 then chains_overlap_pct returned 0.0 depite the overlap between the two chains. I will still retry the test ASAP. Thank you Roger.
Seems to be working now thanks Roger
