Is there a limitation to the number of Stockmodels that Mastercam can handle before the generation and regeneration of the stock models slows down to make it unusable?
I am currently stuck in 2021 because of a customer.
The first few Stock models generate fairly quickly. Then they start to slow down, even to the point where I have to just turn delete tham because they are taking an hour or more to generate.
What are solutions that you have come up with to stay efficient?
The Multi-threading option in config is enabled. Thanks for the suggestion.
Thanks for the response James.
The wash rinse and repeat is my normal way of creating StockModels. Including the CTRL mouseclick to deselect the operations so that it is not regenerationg the toolpath, just using the Pmesh.
But after i get a large number of stockmodels, it takes longer and longer to generate a new stockmodel.
Watching the status of the multi-threading dialog box is painfu
