G143 Z/W syncing macro
First of all, I want to thank you all for your support. I've learned a great deal about editing posts from reading through the forums. however, I am now stuck....lol
I'm programming a Kuraki HBM, Fanuc style code, with a rotating table. The spindle moves in "Z" and the entire column moves in "W". The machine came with a built in macro that synchronizes Z and W so that we can choose which axis we want to move when drilling, tapping, etc. What I'm trying to set up is a "miscellaneous function" (mi4) switch so I can choose which positioning method I want to apply so I don't have to manage two posts(I also program a Femco HBM, Fanuc, with the same definition/post). Below is the NC statement as we want it to read for our purposes, a copy of the edits I have made attempting it and a copy of the NC code it is generating. A little more info to help....the controller uses G143 in place of G43, and A54.(55.,56.,etc) (with decimal) in place of G54 (55.,56.,etc) when it sets up the macro. I also have to disengage the macro with G149 instead of G49. The NC statement as we want it to read:
G90
G143 A54. X-19.135 Y7.355 Z2. W-5. H1 S1000 M3
Z and W would be commented in as "0", so that the operator has control over the spindle projection
The NC code it is generating:
G20
G0 G17 G40 G49 G80 G90
G0 G90 A54 X-19.135 Y7.355 S1000 M3
G43 H1 Z2. M8
G98 G81 Z-.01 R.1 F2.
X-16.043 Y12.762
X-11.559 Y16.931
X-6.049 Y19.587
X0. Y20.5
X6.049 Y19.587
X11.559 Y16.931
X16.043 Y12.762
X19.135 Y7.355
G80
M5
G149 Z15. M9
G91 G30 Y0.
M00
G90
G143 A54 X17.7535 Y10.25 Z2. W-5. H1 S1000 M3
G0 Z2. M8
X10.25 Y17.7535
X4.4139 Y20.0192
X-4.4139
X-10.25 Y17.7535
X-17.7535 Y10.25
G80
M5
G149 Z15. M9
G91 G30 Y0.
Note I have several problems here...The first block is supposed to use a normal positioning technique, but I changed the sign for G_WCS to "A" to get the macro to post correctly. I can change this back to "G" and comment in the "A54." (barely have need of more than one work coordinate), but I don't know how to make the decimal appear in this location only. Second, the first block of code should have canceled cutter length with the normal G49 but it seems to be reading from the next operation? The second block posts correctly, except for that decimal point. Here are the sections of my post as I have it now:
psof$ #Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools$ = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool$
pbld, n$, *smetric, e$
pbld, n$, *sgcode, *sgplane, scc0, sg49, sg80, *sgabsinc, e$
sav_absinc = absinc$
if mi1$ <= one, #Work coordinate system
absinc$ = one
pfbld, n$, sgabsinc, *sg28ref, "Y0.", e$
#pfbld, n$, *sg28ref, "X0.", "Y0.", e$
pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
absinc$ = sav_absinc
pcom_moveb
pcheckaxis
ptoolcomment
comment$
pcan
#pbld, n$, *t$, sm06, e$
pindex
if mi1$ > one, absinc$ = zero
if mi4$ = one,
[pbld, n$, *sgabsinc, e$
pcan1, pbld, n$, sg143, pwcs, pfxout, pfyout, "Z2.", "W-5.", pfcout,
*tlngno$, [if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, e$
pbld, n$, *sgcode, pfzout, scoolant, e$]
else,
[pcan1, pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
pbld, n$, sg43, *tlngno$, pfzout, scoolant, e$]
pbld, n$, sgabsinc, e$
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
ptlchg$ #Tool change
pcuttype
toolchng = one
if mi1$ = one, #Work coordinate system
if prog_stop = 1, pbld, n$, *sm01, e$
if prog_stop = 2, pbld, n$, *sm00, e$
pcom_moveb
pcheckaxis
ptoolcomment
comment$
pcan
result = newfs(15, feed) #Reset the output format for 'feed'
pindex
pcan1, pbld, n$, *sgabsinc, e$
if mi4$ = one,
[pbld, n$, pcan1, pbld, sg143, pwcs, pfxout, pfyout, "Z2.", "W-5.", pfcout,
else,
pbld, n$, e$
pcom_movea
toolchng = zero
!xnci$, !ynci$, !znci$
# if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
[ # explicitely turned off through a canned text edit
if all_cool_off,
#all coolant off with a single off code here
if coolant_on, pbld, n$, sall_cool_off, e$
coolant_on = zero
else,
local_int = zero
coolantx = zero
while local_int < 20 & coolant_on > 0,
coolantx = and(2^local_int, coolant_on)
local_int = local_int + one
if coolantx > zero,
coolantx = local_int
pbld, n$, scoolantx, e$
coolantx = zero
coolant_on = zero
#cc_pos is reset in the toolchange here
cc_pos$ = zero
gcode$ = zero
pbld, n$, sccomp, *sm05, psub_end_mny, e$
if mi4$ = one,
[pbld, n$, sg149, "Z15.", scoolant, e$
pbld, n$, sgabsinc, sgcode, *sg28ref, "Y0.", e$]
else,
[pbld, n$, sg49, "Z15.", scoolant, e$
#if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
else, pbld, n$, protretinc, e$
coolant$ = sav_coolant
Any help to get this completed would be greatly appreciated!!
  • 1 year later...
Hi Catching Chrome, I saw your post that you have Kuraki HBM. Now  I am retrofitting a Kuraki KBH with Mitsubishi Controller and I am stucked with how to compensate tool length when W and Z axis move.
I noticed in your post that you mentioned about Macro program that synchronize Z and W axis. Is it possible if you could send me this macro program. Thank you very much.
My suggestion to control the format in a specific place only:  Create a variable that is formatted the way that you need, and assign the value of g_wcs$.  Force the output of this variable where you want it instead of using the p_wcs call.
For the G49 output, you are correct in assuming that the next tool path has been read.  You can overcome this by using a 'flag' variable to keep track of the state of the output (whether you have called the sync macro) and use the value of that flag to control when the G149 is output.
What you are trying to do is not easy.  But with persistence, you will get workable code.  :cheers:
