DoNest and label vbs
Felix1c,
The DoNest() function takes two parameters, the first is the path to a nestlist file (*.ini) that includes nesting parameters and a parts list, the second parameter is a boolean flag set to either show or hide the "regular" nesting parameters dialog prior to each nest call.
Below is a typical nestlist that ATP generates on the fly:
[PARAMETERS]
VERSION=10.002
TRUESHAPE=NO
ACCUNEST=0
AUTOATTACHCHAINS=NO
EXACTMODE=0
FITPARTINPART=YES
GUILLOTINECUT=NO
IGNOREHOLES=NO
LABELHEIGHT=0.25
LABELHEIGHTAUTO=YES
OPSELECT_INCLUDE_TOOL_RAD=YES
PARTTOPARTDIST=0.1
PROFILETOLERANCE=0.01
RESOLUTION=1
SEPARATEOPPERSHEET=NO
SHEETFILLDIRECTION=_
SHEETTOPARTDIST=0
SORTMAXVACOPS=NO
SORTMAXVACCHAINS=NO
SORTMINTOOLCHG=YES
SORTMODE=2
STARTINGCORNER=1
STOPBETWEENSHEETS=0
FILLALLSHEETS=NO
RESCBOX=1
TOOLPATHS=YES
WORKOFFSETS=0
WORKOFFSETNUMBERING=2
AUTOORIGINS=YES
SHEETTOSHEETDIST=1
ADDLABELS=YES
GRAINDIRECTION=N
QUANTITY=1
[PART1]
VERSION=10.002
PARTID=0
PREVID=-1
PARTNAME=C:DOCUMENTS AND SETTINGSMGMY DOCUMENTSCABINET SOFTWARE DXF FILESKABNXDONUTCASE5_DXF_REPORT_126SS_TOP_0_F.MCX
PARTLABEL=1
LENGTH=1
WIDTH=1
ADDEDRECTANGULAR=NO
USERRECTANGULAR=NO
MINQUANTITY=20
FILLQUANTITY=0
STEPANGLE=0
PRIORITY=1
COMMONTOOL=NO
MIRROR=NO
GRAINDIRECTION=N
CLUSTERMETHOD=7
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=1
MINMAX-Y=1
CONTOURS_NUMBER=0
NOTES_NUMBER=0
QUANTITY=1
[PART2]
VERSION=10.002
PARTID=0
PREVID=-1
PARTNAME=C:DOCUMENTS AND SETTINGSMGMY DOCUMENTSCABINET SOFTWARE DXF FILESKABNXDONUTCASE5_DXF_REPORT_126SS_TRASH_HOLE_0_F.MCX
PARTLABEL=2
LENGTH=1
WIDTH=1
ADDEDRECTANGULAR=NO
USERRECTANGULAR=NO
MINQUANTITY=20
FILLQUANTITY=0
STEPANGLE=0
PRIORITY=1
COMMONTOOL=NO
MIRROR=NO
GRAINDIRECTION=N
CLUSTERMETHOD=7
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=1
MINMAX-Y=1
CONTOURS_NUMBER=0
NOTES_NUMBER=0
QUANTITY=1
[PART3]
VERSION=10.002
PARTID=0
PREVID=-1
PARTNAME=C:DOCUMENTS AND SETTINGSMGMY DOCUMENTSCABINET SOFTWARE DXF FILESKABNXDONUTCASE5_DXF_REPORT_126SS_TRASH_HOLE_1_F.MCX
PARTLABEL=3
LENGTH=1
WIDTH=1
ADDEDRECTANGULAR=NO
USERRECTANGULAR=NO
MINQUANTITY=20
FILLQUANTITY=0
STEPANGLE=0
PRIORITY=1
COMMONTOOL=NO
MIRROR=NO
GRAINDIRECTION=N
CLUSTERMETHOD=7
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=1
MINMAX-Y=1
CONTOURS_NUMBER=0
NOTES_NUMBER=0
QUANTITY=1
[PART4]
VERSION=10.002
PARTID=0
PREVID=-1
PARTNAME=C:DOCUMENTS AND SETTINGSMGMY DOCUMENTSCABINET SOFTWARE DXF FILESKABNXDONUTCASE5_DXF_REPORT_126SS_TRASH_HOLE_2_F.MCX
PARTLABEL=4
LENGTH=1
WIDTH=1
ADDEDRECTANGULAR=NO
USERRECTANGULAR=NO
MINQUANTITY=20
FILLQUANTITY=0
STEPANGLE=0
PRIORITY=1
COMMONTOOL=NO
MIRROR=NO
GRAINDIRECTION=N
CLUSTERMETHOD=7
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=1
MINMAX-Y=1
CONTOURS_NUMBER=0
NOTES_NUMBER=0
QUANTITY=1
[PART5]
VERSION=10.002
PARTID=0
PREVID=-1
PARTNAME=C:DOCUMENTS AND SETTINGSMGMY DOCUMENTSCABINET SOFTWARE DXF FILESKABNXDONUTCASE5_DXF_REPORT_126SS_TRASH_HOLE_3_F.MCX
PARTLABEL=5
LENGTH=1
WIDTH=1
ADDEDRECTANGULAR=NO
USERRECTANGULAR=NO
MINQUANTITY=20
FILLQUANTITY=0
STEPANGLE=0
PRIORITY=1
COMMONTOOL=NO
MIRROR=NO
GRAINDIRECTION=N
CLUSTERMETHOD=7
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=1
MINMAX-Y=1
CONTOURS_NUMBER=0
NOTES_NUMBER=0
QUANTITY=1
[sHEET1]
VERSION=10.002
SHEETID=1
SHEETNAME=SHEET #1
LENGTH=96
WIDTH=48
ADDEDRECTANGULAR=YES
ORIGINPOINT-X=0
ORIGINPOINT-Y=0
QUANTITY=0
GRAINDIRECTION=X
DELGEO=NO
BASEPOINT-X=0
BASEPOINT-Y=0
MINMAX-X=96
MINMAX-Y=48
AMAR=YES
CONTOURS-NUMBER=0
NOTES-NUMBER=0
MATERIALNAME=1/2_MDF_material
THICKNESS=0
The above file has 3 main sections, [PARAMETERS], [PART] and [sHEET], [PART] is incrememented for each part in the list as is [sHEET] although I usually only sepecify 1 type of sheet per nest.
Below is a function I use to create a nestlist on the fly, bare in mind that some object used here are only relative to my NETHook but you should be able to get the gist of whats going on.
public MC_RETURN MakeNestlist(ArrayList job)
//MC_RETURN result = MC_RETURN.MC_ERROR;
string NestingDefaults = "";
//Get nesting values from Nesting Defaults, need to determine if we are inch or metric
bool isMetric = Mastercam.MCRegistry.IsMetric();
if ( isMetric )
NestingDefaults = Path.Combine(Mastercam.GUI.GetMCRootDir() , Defines.PATH_NESTING_MM_DEFX);
else
NestingDefaults = Path.Combine(Mastercam.GUI.GetMCRootDir() , Defines.PATH_NESTING_DEFX);
if ( !File.Exists(NestingDefaults) )
throw new FileNotFoundException(NestingDefaults);
try
//Iterate all materials in arraylist
foreach (Material materials in job )
// [PARAMETERS]
//Define a new newlist
NestingParams thisNest = new NestingParams();
//thisNest.Accuracy =
thisNest.Toolpaths = true;
thisNest.AddLabels = true;
thisNest.label_height_auto = true;
thisNest.WorkOffsets = 0;
thisNest.WorkOffsetNumbering = 2;
thisNest.AutoOrigins = true;
switch ( materials.Material_Grain )
case Defines.GRAIN_IGNORE:
thisNest.GrainDirection = "N"; //' -- Ignore
break;
case Defines.GRAIN_HORIZ:
thisNest.GrainDirection = "X"; //' -- Horizontal (X Axis)
break;
case Defines.GRAIN_VERTICAL:
thisNest.GrainDirection = "Y"; //' -- Vertical (Y Axis)
break;
// [sHEET]
//Define our sheet
NestingParams.NestingSheet newSheet = new NestingParams.NestingSheet();
newSheet.length = Convert.ToDouble(materials.Material_Length);
newSheet.width = Convert.ToDouble(materials.Material_Width);
newSheet.quantity = Convert.ToInt32(materials.Material_Quantity);
newSheet.Thickness = Convert.ToDouble(materials.Material_Thickness);
newSheet.MaterialName = materials.Material_Name;
//Add the sheet to the list
thisNest.AddSheet(newSheet);
int i = 0;
//Get all parts for this material
ArrayList currParts = materials.Parts();
//Iterate each part in this material
foreach (Part theseParts in currParts)
if (theseParts.Front.ToUpper() == "B")
// Do not nest these parts as they are flagged for
// secondary (back side) operations
materials.AddBackFacePart(theseParts);
materials.HasBackFaceParts = true;
else
i += 1;
// [PART]
NestingParams.NestingPart newPart = new NestingParams.NestingPart();
newPart.part_name = theseParts.MCX;
newPart.part_label = i.ToString();
newPart.priority = Convert.ToInt32(theseParts.Priority);
newPart.Quantity = Convert.ToInt32(theseParts.Quantity);
newPart.mirror = theseParts.Mirror;
//Store the item number
theseParts.NestItemNumber = i.ToString();
//Make sure this part is allowed to rotate but contains no blockdrilling ops
if (theseParts.AllowRotate && !theseParts.BlockDrilled)
switch (materials.Material_Grain)
newPart.grain_direction = "N";
newPart.step_angle = 90;
break;
newPart.grain_direction = "X";
newPart.step_angle = 180;
break;
newPart.grain_direction = "Y";
break;
else
newPart.step_angle = 0;
//Add the part to the list
thisNest.AddPart(newPart);
//Write out the file e.g. CPath to unique material folderNestlist.ini
thisNest.WriteToFile(materials.Nestlist);
catch ( Exception ex )
throw ex;
return MC_RETURN.MC_NOERROR;
  • 3 years later...
Hi,
I tried the VB Script example program above to implement DoNest VBScript function. I get a warning message box:
Box title: Nesting vX4 r22.5
Warning - Nesting not available in this product
But when I'm doing it manually (XForm/Geometry Nesting...), it works.
Someone can give me some help on that
Jaouad
Hi Mike,
Thank you for your reply.
I could not run this VB Script because I got a box message error:
Could you please tell me what is the problem^
Jaouad
