Hi All,
I know there are a lot of vb programmers here so I thought i'd ask. I have a program that checks if a file exists. If not it creates it.
As long as I do not use the routine which creates the file all is good.
If the file does not exist the routine crashes at the streamwriter routine with the error: File is in use by another process. The snippet is here :
If System.IO.File.Exists(strFileName) = False Then
' Create File
Dim file As System.IO.FileStream
file = System.IO.File.Create(strFileName)
End If
' File exist already
Dim objWriter As New System.IO.StreamWriter(strFileName)
' Write Header
objWriter.WriteLine("Job# " & txtJobNumber.Text)
Do I need to close the file after I create it? If so how?
Thanks in advance!!!
Karl
Assuming you want to delete an existing file you could try something like the code below. Note that I didnt test this but it should work.
   Dim objWriter As System.IO.StreamWriter = Nothing
Try
If System.IO.File.Exists(strFileName) Then
' If it exists do we delete it?
System.IO.File.Delete(strFileName)
End If
' Create a new file
objWriter = New System.IO.StreamWriter(strFileName)
' Write Header
Catch ex As Exception
Finally
If Not objWriter Is Nothing Then
objWriter.Close()
End If
End Try
