VBS RunMCommand & Delete Questions
I have a couple questions this time around.
1)The VB Script I am currently working on requires me to delete all splines on a given level. I have not found a way to do this. Any Suggestions?
2)My next question is when using “Call RunMastercamCommand("xxx")” The only way I can get this to work is by putting a ShowString right after it. I have tried putting a for-next loop in after the command with the counter up at 200000000 and the RunMastercamCommand still didn’t work.
Example code:
SelectAll ()
ShowString ("Enter to continue")
Call RunMastercamCommand("simplify")
Call RunMastercamCommand("CombineViews")
Showstring ("Enter to continue")
Every ShowString requires the operator to hit the enter key and I would very much like to avoid that.
Any Suggestions?
Hello
1)I wrote the code below.
can you try it?
GetEntityLevel
 ' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim bRet
' -- Start our search
bRet = StartDBSearch(mc_alive, 8 Or 128)
Do While bRet
'If GetEntityLevel = 1
DeleteEntity(GetEntityEptr)
' -- Get another entity
bRet = NextDBSearch
Loop
Call RunMastercamCommand("OnScreenRegenerate")
End Sub
this is from chook sdk
#define P_ID (ulong)1 ///< Point (bit 0)
#define L_ID (ulong)2 ///< Line (bit 1)
#define A_ID (ulong)4 ///< Arc (bit 2)
#define S_ID (ulong)8 ///< Parametric spline (bit 3)
#define N_ID (ulong)16 ///< Note/Label (bit 4)
#define W_ID (ulong)32 ///< Witness/Leader (bit 5)
#define D_ID (ulong)64 ///< Dimension (bit 6)
#define NB_ID (ulong)128 ///< NURBS curve (bit 7)
#define SURF_ID (ulong)256 ///< All surfaces (bit 8)
#define DB_ID (ulong)512 ///< Database management (bit 9)
#define CONS_ID (ulong)1024 ///< Curve ON Surface (bit 10)
#define CD_ID (ulong)2048 ///< Copious data (bit 11)
#define XH_ID (ulong)4096 ///< Crosshatch (bit 12)
#define CC_ID (ulong)8192 ///< Composite curve (bit 13)
#define ASSOC_ID (ulong)16384 ///< Associative ents (bit 14)
#define CHILD_ID (ulong)0x8000 ///< Nonzero: ignore back pointer (bit 15)
#define SOLID_ID (ulong)0x10000 ///< Solid entity (mc_solid_ent) (bit 16)
#define SOLIDXMT_ID (ulong)0x20000 ///< Solid .x_t file (mc_solid_xmt_ent) (bit 17)
#define FILE_ID (ulong)0x40000 ///< File entity (bit 18)
#define RELIEF_ID (ulong)0x80000 ///< Art Relief Info entity (bit 19)
2)it seems "simplify" command does not support pre-selection.
so you may have to hit enter key..
