Character width
‘Character Width’ is only active with ‘Spacing’ is set to ‘Fixed’.
I cannot say for sure without further digging, but I’d assume that data is stored in the font_attr structure.
The Drafting stuff is declared in DfVars_CH.h.
Now type depending on what you’re dealing with; a Note (v8_note) or Dimension (v8_dim_txt)…
Each of those types contains a font_attr structure.
So you drill down thru the ‘ent’…
For a ‘note’: ent.u.n.params [data item in font_attr]
For a ‘dimension’: ent.u.dm.n.params [data item in font_attr]
To find which [data item in font_attr], I would plug in some unique value for that setting and then look at (in the debugger) what's loaded in the font_attr struct for that ent.
Thanks Roger!
I'm working with Notes (v8_note).
The structure font_attr is defined
typedef struct
p_2d center; /**< center point of arc */
double str_rot; /**< string rotation angle */
double slant; /**< slant angle */
double chr_rot; /**< character rotation angle */
double height; /**< height of character */
double chr_exp; /**< character expansion factor(based on height)*/
double extra_sp; /**< extra char. space facter per unit of height*/
double extra_ln_sp; /**< extra line space factor */
double alt_height; /**< height of character */
double alt_chr_exp; /**< alt char. expansion factor(based on height)*/
/* 2 bytes */
unsigned short alt_color:4; /**< draw color */
unsigned short fill_color:4; /**< fill color */
unsigned short h_txt_aln:2; /**< hort. align.(0-left,1-center,2-right)*/
unsigned short v_txt_aln:3; /**< vert. align.(0-top,1-cap,2-half,3-base,
4-bottom) */
unsigned short path:3; /**< text path (0-right,1-left,2-up,3-down,
4-arc CW, 5-arc CCW); */
/* 2 bytes */
unsigned short space_sty:1; /**< spacing style(0-fixed,1-proportional)*/
unsigned short fill:1; /**< fill region flag */
unsigned short mirror:2; /**< mirror flag (0-no mirror, 1-mirror x,
2-mirrory,3- mirror both)*/
unsigned short filler:12; /**< not used at present, here for alignment */
/* 4 bytes */
MC_BYTE font; /**< display font */
MC_BYTE alt_font; /**< alternate display font */
MC_BYTE text_bx; /**< text box draw flag for top */
MC_BYTE pad; /**< Pad end of structure */
} font_attr;
The 'Character Width' must be one of those elements but don't know which one.
--Titus
Note in the Drafting Options dialog the interplay between the Aspect Ratio and the Character Width.
*When the Spacing Mode is ‘Fixed’ ->
The Aspect Ratio field is grayed-out and Character Width is active.
Notice when you change the Character Width that the value of Aspect Ratio changes.
*When the Spacing Mode is ‘Proportional’ ->
The Character Width field is grayed-out and is Aspect Ratio active.
Notice when you change the Aspect Ratio that the value of Character Width changes.
So you see that these 2 settings (on the dialog ) are ‘linked’.
Some experimentation shows us that the ‘link’ is -> Aspect Ratio = width/height.
With…
Width = Character Width
Height = Text Height
*In the end we see that Character Width is not stored and it is the Aspect Ratio value is that gets written to the font_attr struct data in chr_exp.
