Post does not allow to correctly launch external editor
Hello.
I am trying to launch several NC files in external editor in ppost$ block and I have one little problem. Here is how my code looks:
seditor "C:McamX3commoneditorsCIMCOEdit5CIMCOEdit.exe"
s_iteral
s_main_spindle
s_sub_spindle
s_nc_files
ppost$
s_main_spindle = spathnc$ + snamenc$ + sextnc$
s_sub_spindle = spathnc$ + snamesub$ + sextnc$
s_iteral = no2asc(34)
s_nc_files = s_iteral + s_main_spindle + s_iteral + " " + s_iteral + s_sub_spindle + s_iteral
result = launch(seditor, s_nc_files)
Both files are getting opened in the Cimco Edit, but the problem is that the posting does not finish after launching EXE file. Mastercam just waits there until I CLOSE the editor and only then it finishes with posting. I don't want to close the editor - I want to leave it open.
Is there any solution to this?
The easiest method to launch multiple files in an editor is to add them to the list by using the setncstr function.
You should be able to modify this code to work:
      sfile = spathnc$ + snamenc$ + sextnc$  #Set file path
result = setncstr(2, sfile) #Add to edit list so file will open in editor
#2 indicates add, 3 indicates remove from list
Update sfile for each file you wish to add (don't forget to initialize any user defined variable you may use, including sfile).
Hello,
I just tried this function but the result is still not the way I would like.
This is the code:
sit = no2asc(34)
sfile = sit + spathnc$ + snamenc$ + sextnc$+ sit + " " + sit + spathnc$ + snamesub$ + sextnc$ + sit #Set file path
Mastercam opens both files in the editor and stays "locked" until I manualy close the Cimco editor. After that I can use Mastercam again.
Is this the way this should work?
I would like the editor would stay open and Mastercam "unlocked".
Best Regards
Gorazd
