4th axis woes...... hot job of course
SledGeek
I had posted this in industrial but maybe this is a better place for it.  I am trying to cut a releif on a cam, but not having much luck. It verifies nicely but will not cut properly. I am not sure if this is a post problem or programming problem. Everything looks good until cutting.
I am using X8 with multi axis on a Oi-MC control. All the rotary positioning works fine but the axis substitution is not. The tool comes down to the start point at what appears to be 180 degrees off and then rotates the wrong way.
If you look at Clearance toolpath group there are 2 axis substition cuts. They are the clearance cuts I am referring to.
Sorry for double posting this in both forums....kinda desperate.
TE225-2-49R.mcx-8
IMG_0349.MOV  Z lock on and only shows first cut.
(T15  - 0.49 FLAT ENDMILL    - H15  - D15  - D0.4900")N100 G00 G17 G20 G40 G80 G90N102 G91 G28 Z0.N104 (COMPENSATION TYPE - COMPUTER)N106 T15 M06 (0.49 FLAT ENDMILL)N108 G00 G17 G90 G54 A106.011 X.87 Y0. S3056 M03N110 G49N112 G94N114 G05.1 Q1N116 G43 H15 Z1.925N118 Z1.275N120 G01 Z.55 F5.N122 G93 A-130.014 F20.23N124 G00 Z1.925N126 G05.1 Q0N128 M05N130 G91 G28 Z0.N132 G28 Y0. A0.N134 G90N136 M30
