Error installing X9 HLE
WoodWallworks
Could you follow the instructions in the attached PDF document and post the contents of the .txt file it creates here? Based on what we've seen online this appears to be an issue where you don't have permission to modify a portion of your registry and this can occur even if you're logged in to an administrator account.
Checking computer specs and graphics card.pdf
I also have the log file from when i got the error. (if its of any use)
System Information
Time of this report: 6/23/2016, 17:37:21
       Machine name: HIPPO-PC
   Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150525-0603)
           Language: English (Regional Setting: English)
System Manufacturer: To be filled by O.E.M.
       System Model: To be filled by O.E.M.
               BIOS: BIOS Date: 10/20/10 09:47:36 Ver: 08.00.10
          Processor: AMD FX-4100 Quad-Core Processor             (4 CPUs), ~3.6GHz
             Memory: 16384MB RAM
Available OS Memory: 16330MB RAM
          Page File: 3657MB used, 28999MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: AMD Radeon HD 7900 Series
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon Graphics Processor (0x679A)
           DAC type: Internal DAC(400MHz)
         Device Key: Enum\PCI\VEN_1002&DEV_679A&SUBSYS_32201682&REV_00
     Display Memory: 4095 MB
   Dedicated Memory: 3051 MB
      Shared Memory: 1044 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: D2342P
         Monitor Id: GSM5842
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1404 (English)
     Driver Version: 15.200.1062.0
        DDI Version: 11
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 7/15/2015 22:11:48, 1445224 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71EE2-24DA-11CF-4E70-2A12BEC2C535}
          Vendor ID: 0x1002
          Device ID: 0x679A
          SubSys ID: 0x32201682
        Revision ID: 0x0000
 Driver Strong Name: oem39.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R575:15.200.1062.0:pci\ven_1002&dev_679a
     Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
      Monitor Model: SAMSUNG
         Monitor Id: SAM0390
        Output Type: HDMI
        DDI Version: 11
        WHQL Logo'd: Yes
    WHQL Date Stamp:
          Vendor ID: 0x1002
          Device ID: 0x679A
        Revision ID: 0x0000
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Keyboard Audio (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438410&REV_1003
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.6251 (English)
            WHQL Logo'd: Yes
          Date and Size: 11/23/2010 06:16:56, 2565736 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX 2.0 Listen/Src: No, No
   I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Sound Capture Devices
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Controller (XBOX 360 For Windows)
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x028E
        FF Driver: n/a
      Device Name: Razer BlackWidow Chroma
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0203
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Razer BlackWidow Chroma
| Matching Device ID: hid\vid_1532&pid_0203&mi_01&col01
| Upper Filters: rzudd
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x093A, 0x2521
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Matching Device ID: hid\vid_1532&pid_0203&mi_02
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 164.8 GB
Total Space: 953.8 GB
File System: NTFS
      Model: Samsung SSD 850 EVO 1TB SATA Disk Device
      Drive: D:
      Model: TSSTcorp CDDVDW SH-S203B SATA CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_84321043&REV_06\4&2799F330&0&0020
   Driver: n/a
     Name: AMD Radeon HD 7900 Series
Device ID: PCI\VEN_1002&DEV_679A&SUBSYS_32201682&REV_00\4&14E8F4CB&0&0010
   Driver: n/a
     Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_43991002&REV_00\3&267A616A&0&A5
   Driver: n/a
     Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_43851002&REV_42\3&267A616A&0&A0
   Driver: n/a
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1605&SUBSYS_00000000&REV_00\3&267A616A&0&C5
   Driver: n/a
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_5A1B&SUBSYS_5A141002&REV_00\3&267A616A&0&38
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&B0
   Driver: n/a
     Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&267A616A&0&A4
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1604&SUBSYS_00000000&REV_00\3&267A616A&0&C4
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A1A&SUBSYS_5A141002&REV_00\3&267A616A&0&30
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&98
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_84101043&REV_40\3&267A616A&0&A2
   Driver: n/a
     Name: Universal Serial Bus (USB) Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&312AFB2E&0&0028
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1603&SUBSYS_00000000&REV_00\3&267A616A&0&C3
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A19&SUBSYS_5A141002&REV_00\3&267A616A&0&28
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&0&90
   Driver: n/a
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&1C9B094&0&0038
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1602&SUBSYS_00000000&REV_00\3&267A616A&0&C2
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A18&SUBSYS_5A141002&REV_00\3&267A616A&0&20
   Driver: n/a
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&B2
   Driver: n/a
     Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&30401175&1&0030
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1601&SUBSYS_00000000&REV_00\3&267A616A&0&C1
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A16&SUBSYS_5A141002&REV_00\3&267A616A&0&10
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&9A
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1600&SUBSYS_00000000&REV_00\3&267A616A&0&C0
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A14&SUBSYS_5A141002&REV_02\3&267A616A&0&00
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&0&92
   Driver: n/a
     Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&2B4059EA&0&38A4
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_AAA0&SUBSYS_AAA01682&REV_00\4&14E8F4CB&0&0110
   Driver: n/a
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_439D1002&REV_40\3&267A616A&0&A3
   Driver: n/a
     Name: AMD SATA Controller
Device ID: PCI\VEN_1002&DEV_4391&SUBSYS_84DD1043&REV_40\3&267A616A&0&88
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
MainConcept MPEG-2 Video Encoder,0x00200000,2,1,mcm2ve.ax,7.04.0000.35746
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
MainConcept Layer II Audio Encoder,0x00100000,1,1,mcl2ae.ax,7.03.0000.35746
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.18741
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.18741
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.18741
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.18741
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
ATI MPEG File Writer,0x00200000,1,0,atimpenc.dll,13.30.0000.41120
AMD Video Decoder,0x00200000,1,2,atimpenc.dll,13.30.0000.41120
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.18741
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.18741
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,13.30.0000.41120
AMD MJPEG Decoder,0x00200000,1,1,atimpenc.dll,13.30.0000.41120
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.18741
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.18741
AMD Video Encoder,0x00200000,1,1,atimpenc.dll,13.30.0000.41120
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc.dll,13.30.0000.41120
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
AMD Video Scaler Filter,0x00200000,1,1,atimpenc.dll,13.30.0000.41120
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.18741
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.18741
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.18741
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18501
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18501
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.18741
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
MainConcept MPEG Multiplexer-Plus,0x00200000,1,1,mcmpeg2mux.ax,7.06.0000.35746
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.18741
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.18741
AMD Video Rotation Filter,0x00200000,1,1,atimpenc.dll,13.30.0000.41120
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.18741
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.18741
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.18741
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.18741
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.18741
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MainConcept MPEG-2 Video Encoder,0x00400000,2,1,mcm2ve.ax,7.04.0000.35746
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18741
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
MainConcept Layer II Audio Encoder,0x00800001,1,1,mcl2ae.ax,7.03.0000.35746
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.18741
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18741
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
Line in at front panel (Green),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Mic in at front panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Line in at rear panel (Blue),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Mic in at rear panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Razer Surround Audio Controller,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
AMD HD Audio HDMI out #0,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
AMD HD Audio HDMI out #1,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Keyboard Audio (Realtek High De,0x00200000,1,0,quartz.dll,6.06.7601.18741
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Keyboard Audio (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
