Tab key not working
I've created a window with a nethook by using the Form1.show method and everything is working the way I want it except for the tab key isn't tabbing through the controls the way I would normally expect. Anyone seen this before or know why? I tried using the keydown event to catch the Tab key and change the focus to the next control and that works but it makes a warning sound on text boxes which I haven't figured out yet. Buttons don't make the sound.
You should not need to anything "special" for Tabbing between controls on a .NET WinForm
I would suggest checking the Properties of the controls on your Form.
Is the TabStop property set to True ?
Other than that setting, all you need to do is check the TabIndex values for each control to make sure that a "proper" order is being specified.
Tabstop is true and TabIndex values are all correct. 0 for the first 1 for the second and so on. If I run the form as a stand alone application it works fine. It's just when it running inside a nethook with mastercam that the tab key won't work. All it does when I press the tab key is make a warning noise and focus stays on the same control.
With this code my Tab key works "as expected" ->
#region NETHOOK class
public class NETHOOK : Mastercam.App.NetHook2App
// Entry Point
public override Mastercam.App.Types.MCamReturn Run(int param)
if (!FindRequiredInteropSupportFiles(false))
return Mastercam.App.Types.MCamReturn.ErrorOccurred;
try
frmPolarPointData2Geometry form = new frmPolarPointData2Geometry();
form.ShowDialog(); // * Show the Form *
catch (Exception ex)
MessageBox.Show(ex.Message, "UnHandled Exception: " + ex.Source,
MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
return Mastercam.App.Types.MCamReturn.NoErrors;
} // class NETHOOK
#endregion class NETHOOK
In the past I've used Form1.ShowDialog() as well and had very good results. The problem I believe is that with ShowDialog() Form1 holds focus and the user can't manipulate the Mastercam graphics window.
Do you know if it's possible to use Form1.Show() as oposed to ShowDialog() but somehow stay within the NetHook Run() method? I'm hoping this would give me the desired results. Currently I think the problem is that Form1 opens as an instance but then the NetHook actually continues through the rest of the code and ends up running the Close() method. This leaves Form1 still open and operating but also allows the user to set focus back to Mastercam which is my tentative goal. smile.gif
Matt,
I investigated "Modeless Dialog with a NETHook".
And the answer was I got was ->
You could display a modeless dialog, but there’s no get_event()-type support in the NetHook API. It just wasn’t designed for that.
There is some event-driven abilities, but it’s not that extensive and ff you’re doing serious event tracking for mouse movements and the like, odds are good that your app is extensive enough that you should probably be looking at a CHook anyway.
I've done a couple CHooks that use modeless dialogs,
but never needed to with a NETHook.
On the subject of Tab Stops...
Of course this is all moot in regard to the primary subject at hand...
Some Googling turned up this ->
Microsoft Support: Modeless Dialog Box in a DLL Does Not Process TAB Key
*This behavior is by design.*
Windows Hooks in the .NET Framework
and
How to set a Windows hook in Visual C# .NET
and
SEE Ying-Shen Yu's answer to Ken Beccard's question
Implementing a Hook, I was able to "capture" the messages coming to my DLL.
The TAB Key did move the cursor between the controls, but not by the defined Tab Order!?!
It wasn't random, it was almost in reverse, but it was certainly not in the order defined by the TabIndex property set on each control.
With the Hook in place and the form now "seeing" the Tab Key I'm fairly sure that the tab order issue could be worked out, even if you had to "manually" move the focus from control->control.
Note: Using the code from the MSDN Magazine Cutting Edge article, the hook is "set" using this code ->
public void Install()
m_hhook = SetWindowsHookEx(
m_hookType, m_filterFunc,
IntPtr.Zero,
(int)AppDomain.GetCurrentThreadId());
But...
AppDomain.GetCurrentThreadId() is a depreciated item.
When you build the Project you get this Warning->
System.AppDomain.GetCurrentThreadId()' is obsolete: 'AppDomain.GetCurrentThreadId has been deprecated because it does not provide a stable Id when managed threads are running on fibers (aka lightweight threads). To get a stable identifier for a managed thread, use the ManagedThreadId property on Thread.
I did not find a around this (and didn't try too hard!) as the resulting DLL will run, but you always have to be very leery of using "depreciated" items!!!
Wow, thanks a lot Roger. That's all great info. I think the first part pretty much sums it up. "It just wasn't designed for that." I'm going to try a few things with what I've learned here and see how I make out. If I can't get anywhere with it fairly easily I have found a reasonable work around that I will use instead. I'll simply set up a button that takes the focus back to the Mastercam window like the "Hide Dialog" button in the FBM window. That should be easy enough to figure out.
Looks like it might be time to take the plunge into Chooks.
Thanks for all the help Roger.
