G300 POSTING
COREY@SSI
This is my first time editing a post with x3
im starting to use master cam on my tsugami swiss machine and have been doing chop and paste with the code and now im interested in getting my post working correctly
im using the generic fanuc 4x post that came on the disc and i have my program head mostly configured excep for one line
my program head looks like this
O3031(CHECK VALVE)
M91
/M61
M93032
N10(START UP)
M501
G00G18G99T0/M08
M11
G300X-0.08Z1.256T0800 g300 is my problem
G150Z-0.008
M10
G00X5.4331Z-0.04T0
M502
g300 sets the stroke of the machine so the main collet doesnt hit the guide bushing
my plan was to use the stock length in stock setup to set the part lenght then add .580 to it in the post
i havent gotten to the math part yet but i did finally get the post to output the part length with a little extra junk attached
O0000
(PROGRAM NAME - TSUGAMI PROOFING)
(DATE=DD-MM-YY - 28-08-09 TIME=HH:MM - 16:05)
(MCX FILE - C:MCAMX3MCXTSUGAMI PROOFING.MCX)
(NC FILE - C:MCAMX3LATHENCTSUGAMI PROOFING.NC)
(MATERIAL - STEEL INCH - 1030 - 200 BHN)
G20
M91
/M61
M90000
N10(START UP)
M501;
G00G18G99T0/M08
M11;
G150Z-0.008
M10
G00X5.4331Z-0.04T0
M502
and here is what my post looks like at the moment
# Start of File and Toolchange Setup
ptime #Convert 24-hour time format into 12-hour AM/PM format
if time$ >= 13, time2 = (time$ - 12)
else, time2 = time$
hour = int(time2), min = frac(time2)
*hour, ":", *min,
if time$ > 12, " PM"
else, " AM"
pheader$ #Start of file
"%", e$
sav_spc = spaces$
spaces$ = 0
#*progno$, " (", sprogname$, ")", e$
*progno$, e$
"(", "PROGRAM NAME - ", sprogname$, ")", e$
"(", "DATE=DD-MM-YY - ", date$, " TIME=HH:MM - ", time$, ")", e$ #Date and time output Ex. 12-02-05 15:52
#"(", "DATE - ", month$, "-", day$, "-", year$, ")", e$ #Date output as month,day,year - Ex. 02-12-05
#"(", "DATE - ", *smonth, " ", day$, " ", *year2, ")", e$ #Date output as month,day,year - Ex. Feb. 12 2005
#"(", "TIME - ", time$, ")", e$ #24 hour time output - Ex. 15:52
#"(", "TIME - ", ptime ")", e$ #12 hour time output 3:52 PM
spathnc$ = ucase(spathnc$)
smcname$ = ucase(smcname$)
stck_matl$ = ucase(stck_matl$)
snamenc$ = ucase(snamenc$)
"(", "MCX FILE - ", *smcpath$, *smcname$, *smcext$, ")", e$
"(", "NC FILE - ", *spathnc$, *snamenc$, *sextnc$, ")", e$
"(", "MATERIAL - ", *stck_matl$, ")", e$
spaces$ = sav_spc
pbld, n$, *smetric, e$
"M91"e$
"/M61"e$
"M90000"e$
"N10(START UP)"e$
"M501;"e$
"G00G18G99T0/M08"e$
"M11;"e$
"G150Z-0.008"e$
"M10"e$
"G00X5.4331Z-0.04T0"e$
"M502"e$
Search for fmt.
fmt  T  4   t$          #Tool No
fmt T 4 first_tool$ #First Tool Used
fmt T 4 next_tool$ #Next Tool Used
fmt D 4 tloffno$ #Diameter Offset No
fmt H 4 tlngno$ #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
In this section of the post, variables are formatted or declared.
Search for fs2.
In this section the formats are defined.
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 8 5 0 5 0l #Integer, force five leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate)
fs2 16 1 0 1 0n #Integer, forced output
fs2 17 1.4 1.3lt #Decimal, absolute, 4/3 trailing
Lets assume you want the variable stck_ht$ to output as a "Z" and have 4 decimal places.
Add a line to format the variable.
fmt  T  4   t$          #Tool No
fmt Z 12 stck_ht$ #Stock height for G300 line
The 12 refers to the fs2 statement numbered 12 describing a 4 place decimal.
Now stck_ht$ will output as a "Z".
You can now change this line:
"G300X-0.08","Z",*stck_ht$,"T0800"e$
To:
"G300X-0.08",*stck_ht$,"T0800"e$
You should get the output you're looking for now.
i emailed my contact at my reseller to get the guide but i have another question
lets say i want to add a value to the stock_ht value
i use it in 2 places
the first in the g300 line where i need to add 1/2 an inch
the second is my partoff/transfer
i want to add .01 just so i have shock to clean up.
ive been scrolling thru the post trying to find the formatting to add to the value but im coming up dry
Instead of altering the value in pre-defined variable stck_ht$ I would suggest decalring your own variable and then assign the desired value (stck_ht$ + value) to your user-defined variable.
Where Mastercam Guru shows formatting stck_ht$ do this instead ->
fmt Z 12 g300value #Stock height for G300 line
Now in the postblock(s) where you need to output ...
g300value = stck_ht$ + 0.5
"G300X-0.08", *g300value, "T0800", e$
