Welcome to eMastercam.com
Surface Finish Flowline
  • Please log in to reply
4 replies to this topic
#1
javi11
javi11
    Member
  • Members
  • PipPip
  • 36 posts
Good morning,
im working on a part that has unique angles, making it tough to get a bull mill to cut in a single pass. I'm trying to figure out how can i make depth cuts using the surface finish flowline. Appreciate your help and happy holidays.
#2
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,231 posts
1st off, are you are there is a Surface Rough Flowline?
2nd, If you're trying to do depth of cuts with the finish path, create the finish path, then copy it and change it to leave the stock on conditon
1st pass might have .05 stock on
2nd pass .025 stock
last pass would have 0 stock
#3
javi11
javi11
    Member
  • Members
  • PipPip
  • 36 posts
alright sounds good i will try to create that toolpath. by the way, is there an actual way to create depth cuts on finish without having to copy the previous operation?
#4
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,231 posts
NO, it's a finish path, not designed for depths of cut
#5
javi11
javi11
    Member
  • Members
  • PipPip
  • 36 posts
thank you. appreciate the help
