Chook adjust Tolerance
I am interested in adjusting the tolerance distribution using the C-Hook. I’ve successfully extracted and modified the smoothing tolerance using the following code:
currentOperation->smoothing_3d.m_smoothTol = 0.00125;
However, I’m encountering difficulty modifying the total tolerance or cut tolerance. I’ve been able to access these through the Net-Hook, where the name is provided directly. Unfortunately, the same control is not available through the C-Hook. I am seeking guidance on how to gain control over both the “Cut Tolerance Percentage” and the “Total Tolerance” using the C-Hook.
Additionally, I came across the following code snippet in the SDK, which appears to be related to implementing filter_tolerance in the structure prm_srf_hmm:
struct prm_srf_hmm
    double cut_tolerance; // the cut tolerance (add filter_tolerance to get total tolerance)
However, it seems that the filter_tolerance has not been implemented anywhere. Can you provide assistance in determining if this snippet holds the solution to my requirement?
