5-axis axis post question
Guayaco
Guest SAIPEM
The Primary or "Master" Rotary Axis is the driving Rotary Axis and the Secondary or "Slave" Rotary Axis is the driven Rotary axis.
This means that the position of the secondary axis is dependent on the position of the primary axis.
The math for calculating the angles for each from the tool vectors is different depending on the rotary axis configuration.
I Vector = 0.1227878
J Vector = 0.1227878
K Vector = 0.98480775
Mighty USA B-5000 5BC
Master - Angle C = 45.0
Slave - Angle B = 10.0
Haas VR-11
Master - Angle B = 7.1070759
Slave - Angle A = -7.0530219
SNK PC-60V
Master - Angle A = -7.1070759
Slave - Angle B = 7.0530219
Here's the non-mathematical explanation. Most 5-axis machines can take either of two positions to satisfy the tool axis vector. The postprocessor is biased so that it will not switch back and forth between them during a cut. Often the primary position faces the work towards the operator more than the secondary.
