X2 Posting Speed of Zero
VBJB
I recently updated to X2 and now my speeds are all posting out as zero. I have downloaded and applied the mpMaster post update and ran the updatePost.dll. I also checked and made sure my machine definition has a spindle with a spindle range of 0-8000 RPM.
What else do I need to check?
VBJB, its just a number that has to be changed, I have the info on my pc at work , I will give you the info in the morning
[shame on us for trying to exploit the Machine Def...]
Sorry Dave I shouldnt of called it a bug, because it really isnt, its just a number change, I really like the mpmaster posts, and the new changes in x2.
Any parameter lookups on min_speed and max_speed need to read:
      17608   min_speed    #Minimum spindle speed
17609 max_speed #Maximum spindle speed
while they used to be
      17605   min_speed    #Minimum spindle speed
17606 max_speed #Maximum spindle speed
or even
17613 min_speed #Minimum spindle speed
17614 max_speed #Maximum spindle speed
In X2, each value is 3 better. Hope you enjoy the improvement.
[ 11-03-2006, 01:58 PM: Message edited by: Dave Thomson ]
  • 2 months later...
I guess I will need to post every time someone begins a thread like this. X2 has a bug in the parameter output for the Milling spindle min/max speed settings.
They are supposed to be:
and are coming out as:
Changing these values will fix the issue until the X2-SP1 release. Then you will have to go back in and change them back to 17605 and 17606.
In reality however, these checks are not really needed at all as it is impossible to program outside of the specified range in Mastercam.
You may want to just modify the pspindle postblock, removing the min.max check altogether to something like:
pspindle        #Spindle speed calculations for RPM
speed = abs(ss$)
spdir2 = fsg3(spdir$)
  • 8 months later...
  • 11 months later...
Good day,
That fixed it for me
Tony G
CNCme Engineering
X Beta Site
SO Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
