Missing M08
CNCGUY
When posting a program, the M08 will not post. I did some searching and found what should fix it "support coolant using coolant value in post-processor". I have "checked" this, but still no M08. Any ideas?
Using a modified V9 Fanuc Post updated to X.
Setting "Support coolant using coolant value in post-processor" (in the Mach. Def.) is correct for a 'V9' style post updated for 'X'.
Once that is done and still no joy, it's time for some investigating...
First, it's assumed that you have programmed coolant ON in the toolpath operation in question. wink.gif
In a 'v9' style MPFAN.PST
The Coolant command (strings) are usually defined like this ->
# Coolant M code selection
sm09 M9 #Coolant Off
sm08 M8 #Coolant Flood
sm08_1 M8 #Coolant Mist
sm08_2 M8 #Coolant Tool
scoolant #Target for string
And in the psof$, ptlchg0$ and ptlchg$ postblocks you should have the scoolant command.
(All of these pre-defined postblock names and pre-defined post variable names
will have a '$' append on them when the post was updated for use with 'X').
Something like this ->
pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool$, e$
You can make sure the the scoolant string selector is working by doing this test...
Add '*' in front of the scoolant command in psof$.
Like this ->
pbld, n, "G43", *tlngno, pfzout, *scoolant, next_tool$, e$
You should now at least see an 'M9' output on the initial tool's "G43" block ->
N108 G43 H1 Z.25 M9
Still nothing?
Make sure that you did not add a '$' on the scoolant$, as it is not a pre-defined variable,
and this will cause "nothing" to output.
