Setup sheet Bombs out
Slixmix
Using v9 sp1 level 3 w/solids. Settings are for .set setup sheet and is html in my config file. Everytime I go to write the html (it actually says .doc file) my computer crashes with the famous last words:
Mill9.exe has generated errors and will be closed by windows. You will need to restart the program.
Any help? Thanks
Which option is set on your config on the NC settings page?
1> Post (uses .SET file)
2> Using Graphical Interface
The '1' setting produces a text file (with a .DOC filename).
The '2' setting produces an HTML file.
Are you running Mill, Lathe, or???
Very strange...
Does this occur with ANY MC9 file?
What OS is on your computer?
If you wish, you can e-mail me the MC9 file that causes this problem when trying to generate the .DOC setup sheet file. I also MUST have the .SET file that is being used.
You can determine the .SET filename by ->
Screen, Config, Files, highlite 'Setup Sheet Template' in the File Usage area, then read the
File Name below.
Windows 2000 service pack 2
Dell Lattitude C810 laptop
1.4 ghz p3
1/2 gig ram
32 mb Nvidia Geforce 2 Go
Because of non-disclosure agreements I cannot send the damn file! Sorry about that. We do work out here in Silicon Valley for Semiconductor chip makers.
