API threading on Lathe
cadman2112
Is is me, or does Mastercam have trouble outputting correct code for an API thread?
I searched and only found one thread where someone mentioned the trouble and asked if anyone else had a solution.
Looking at the Fanuc manuals it is requesting different information than the current thread cycles puts out.
Is there anyone cutting API threads using Mastercam?
I cut lots of API threads, I pick my major Dia on the small end of taper,(using an external API as an example) calculate the minor Dia from the Depth of thread on the API spec, then calculate the Taper per foot for the specific thread, Example: 2" taper per foot is 4.731 deg. Then put the 4.731 in the Thread shape parameters area, the taper angle box is located at the bottom left of parameters page. Once you enter a value in the Taper angle box, Pick which end of the Taper is the Major Dia,... So if you are cutting an external API, Select the Major Dia at the small end and also check the area which says "Large end of taper or small end of taper"
If your tool is going the opposite way that you need on the taper, then put a negative value in the Taper angle box, I think an Internal API uses a negative value, an external taper uses a positive value.
Jarrett,
Thanks for the response.
The problem I see is we have coded these for a period of time and the machines, even the manual seems to call that on an external for example, the Major or ending diameter is what should be output on the G76 line.
Mastercam no matter what settings, I can not get this to output the way I Need to see it..
Here is a sample from one of my programs, it has start and end point of thread, and the R value is what mastercam calculates how much to move in X.
This post is pretty much a standard Fanuc post with a couple tweaks, I run it on a Daowoo Puma lathe.
(TOOL - 3 OFFSET - 3)
(4 TPI EXT API INSERT )
N1(OPERATION 1)
G54
M8
M43
G97S500M04T0303
G0X2.537Z.2
G99G92X2.3181Z-2.64R-.235F.25
X2.3025
X2.2889
X2.2767
X2.2656
X2.2552
X2.2455
X2.2364
X2.2277
X2.2194
X2.2114
X2.2038
X2.1964
X2.1893
X2.1824
X2.1757
X2.1692
X2.1628
X2.1567
X2.1506
X2.1447
X2.139
X2.137
X2.137
G0X2.537
M9
G28U0.
G0Z10.
M30
pg76$ #G76 threading
comment$
gcode$ = zero
lrapid$
sav_xa = vequ(copy_x)
>>>> if thdface$ = zero, copy_x = thdx3$ #Changed from thdx2$ so X value in G76 line is end X--BLG
else, copy_z = thdx2$
if thdface$ = zero, copy_z = thdz2$
else, copy_x = thdz2$
pcom_moveb
It has been awhile, but I believe line #5 in the above post block is the only thing I changed to fix this.
