group type in MC API
ksoufi
In the mill text file there is a section thal looks like this;
[groups]
1. "Group already exists with the same name."
2. "Select entities to add to group(s)"
3. "Group does not exist."
4. "Unable to read groups from file!"
5. "Enter unique group name"
6. "Restoring group members..."
7. "Current system GROUP"
8. "Current system RESULT"
9. "Select entities to remove from group(s)"
10. "Deleting Groups"
11. "Are you sure?"
12. "Select geometry that belongs to a group"
13. "Groups are used in toolpath operations. Are you sure?"
14. "XXXXXXXX-XXX"
15. "XXXXXXXX-XX1"
16. "Naming a group 'UNDEFINED' is not allowed."
17. " entities in selected group(s)"
(default group name - a number will be added to this)
20. "Group"
The "X" is how I have MC name it different from "Toolpath Group".
ksoufi,
I think you might be having the same problem I'm having. In chooks you use the functions in m_db.h to create, delete, and add entities to groups.
list_grp_add_empty
list_grp_add_ents
list_grp_append_ents
list_grp_remove_ents
They all take a 'name' variable. But unless you created the group how do you know the 'name'? right?
For the life of me I can't find a function to get a list of current group names. I think this is the same problem you're having. right?
Maybe Product Developement Guy or one of the other developers could help.
I know the 'op_common' structure in 'm_avars.h' refer to a group idn number but I can't find how use the group number to get the group name.
Bryan & James
Thanks for reply
In fact i'm trying to do this :
_____________________________________________
//create a new group
list_grp_add_empty ("group1",TRUE,1,&succf);
if (!succf)
return;
//add entities to group
list_grp_append_ents ("group1",1,&e_ptr,&succf)______________________________________________
There is two problem
1) th 1st one is after creating successfuly the "group1" and when running the list_grp_append_ents , there's a warning msg dlg box : memory allocation error
and then it pops up a second dlg box: this time is a Debug message :
list_grp_append(2)
Temporary file cfeated .....
2) the second problem is that once the "group1" was created, it doesn't appear in the list of Groups dlg box. When trying to create a new group by the icon "new", it gives me a warning : group1 already exists with the same name. This's what you said Bryan, there's no function to retrieve group from list_group!
there's allso some questions about the "type" input, what's exactly?!
Let's see, under list_grp_add_empty and list_grp_add_ents the 'type' (short type) is the type of group to create.
0=geometry - normal group for adding entities - ie lines, points, and arcs.
1=operations - groups seen in the operation manager - adding toolpaths
2=SystemGroup
3=SystemResult - these last two I assume are for creating the groups 'Group' and 'Result' like when to xform-tranlate-copy entites. they're stuck in Group and Result groups.
If you're trying to add geometry like lines and arcs to a group that might be part of your trouble. Your using 1 (operation group)
Another problem is you're calling TRUE in your second variable. This sets the group to hidden. That also might be why it isnt showing up in the group list.
  • 1 year later...
  • 9 months later...
hello
Does anybody know how to append an operation to Toolpath Group 2"?,
    op_list *opl;
list_manager (OP_ID, "", LSTMGR_GET, (void **)&opl);
while (opl != NULL)
list_grp_append_ents ("Toolpath Group 2", // I: new group name
1, // I: number of ents in eptr list, 0=use .sel ents
&opl->eptr, // I: list of entity eptrs
succf);
opl=opl->next_ptr;
