result = nwadrs(strp, main_prg_no)
Rekd™
When using subs in drill cycles, I want to start the sub programs with the first number after the main program. Right now it always goes to 2.
I've tried logic statements that add 1 to "progno" but it no workie. (Actually, it works on the first sub, but the later ones revert to 2 again.) I believe it's because of the "result = nwadrs(strp, sub_prg_no)" line, but I'm not sure what that does. Would anyone like to educate the ignorant??
TYIA
'Rekd
[ 01-24-2003, 11:38 AM: Message edited by: Rekd ]
The NWADRS command allows you to assign a new
format (fmt) prefix to a variable.
In this case, it's assigning whatever string is contained in the string variable STRP to the
formatting of the SUB_PRG_NO variable.
(STRP = "P" in the std MPFAN.PST)
So... this is NOT causing the change you see in the VALUE being output. NWADRS only affects the letter address output when you output the value in SUB_PRG_NO
