chook drafting note - help
Hi,
In trying to enter a note via chooks. I want to enter a note and I know that using v8_note is the way to do it, but I don't know how to do this.
typedef struct              /* structure for notes */
byte type; /* 0=witness, 1=leader, 2=label, 3=note */
p_3d ref_pt; /* reference point (text in view) (Z=depth) */
short view; /* view number that note was created in */
real scale; /* internal scale for detail view */
font_attr params; /* font attributes */
ulong mtid; /* memory table index (allocated string) */
v8_wit_ldr ldr; /* leader/witness associated with entity */
eptr_type xptr; /* conversion pointer: note (always null_eptr) */
boolean assoc; /* this entity uses associativity */
p_3d txtpos; /* incremental position used to regenerate note */
short ldr_count; /* number of leaders */
byte pad[2]; /* pad to 8 bytes "none" */
} v8_note;
I am getting stuck when I run into this "ulong mtid; memory table index ", what is a mtid and how do I get one. I also found a bunch of memory table functions "mTable..." in "M_DRAFT.H", but there is no intuative way of using these.
Does someone know how to make use of all this. I just want to enter a note in my draft.
Girus.
Here's a simple note routine I use
/* MAKE NOTE */
void make_note(
short view, // I: view to create in (view must be >= 1)
p_3d ref_pt, // I: base point relative to view (and alignment) (z = depth)
byte color,
byte level,
char *text) // I: text for note
//note def
ent entity;
db_ptr_type d_ptr;
boolean succf;
//initialize note entity
InitNOTE (&entity);
calc_note(&entity, view, ref_pt, text);
store_ent (&entity, &d_ptr, 0, color, level , main_attrib, &succf);
/* END MAKE NOTE */
Bryan,
I am getting this now.
error C2664: 'unsigned char (ent *,short,double [],unsigned char *)' : cannot convert parameter 4 from 'char *' to 'unsigned char *'
on the char*text
have you ran into this?
Girus.
Girus,
Look in M_DRAFT.H at DraftGlobalsSave, DraftGlobalsRestore, and the other DraftGlobals functions. They might be of some use to you. You can backup your globals, change font size and stuff, initialize/create your note, and then restore them back to normal.
or just modify the values in entity.u.n.params before calling store_ent. Params is a font_attr struct defined in M_VARS.H.
for example:
entity.u.n.params.height = 0.25;
entity.u.n.params.chr_exp =0.50;
  • 4 months later...
Not entirely sure but try the function get_ttfont_number in M_DB.H.
 /* ________ get_truetype_font_number _______
* Given a true type name, italic & weight, search list and find a font
* number. If the font is not found, create a new font and add to the
* ttfontlist array.
EXTERN int (*_get_ttfont_number) (// return: Font number or -1 if error
char *fontname, // I: Font name
unsigned short italic, // I: Italic
unsigned short weight); // I: Weight of font
#define get_ttfont_number (*_get_ttfont_number)
