The example "Shapes" c-hook
Hi All,
I'm just starting on c-hooks for MasterCAM. I tried to copy & implement the SHAPES example and have followed all the steps, including VC++ project settings, and have referred to previous threads on this topic.
I'm still not able to figure out how to get rid of the following errors:
--------------------Configuration: Shapes - Win32 Debug--------------------
Linking...
mfcs42d.lib(dllmodul.obj) : error LNK2005: __pRawDllMain already defined in Shapes.obj
mfcs42d.lib(dllmodul.obj) : warning LNK4006: __pRawDllMain already defined in Shapes.obj; second definition ignored
Creating library Debug/Shapes.lib and object Debug/Shapes.exp
Debug/Shapes.dll : fatal error LNK1169: one or more multiply defined symbols found
Error executing link.exe.
Shapes.dll - 2 error(s), 1 warning(s)
Can anyone help solve this problem?
Thanks very much!
I'm not sure how to use the code tag, but hope this works. I think I copied the content of the Shapes.cpp file 'as is' from the given example code. So, I'll insert only the start and the end of the code here.
// Shapes.cpp : Defines the initialization
#include "stdafx.h"
#include <math.h>
#undef EXPORT
extern "C"
#include "m_vars.h"
#include "m_math.h"
#include "m_menu.h"
#include "m_graph.h"
#include "m_io.h"
#include "m_db.h"
#include "m_chain.h"
#include "m_undo.h"
#include "m_ncvars.h"
#include "m_nc.h"
#include "m_init.h"
void __declspec(dllexport) m_main(long *ptrs);
#include "shapes.h"
#include "shapedlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
BEGIN_MESSAGE_MAP(CShapesApp, CWinApp)
//{{AFX_MSG_MAP(CShapesApp)
// NOTE - the ClassWizard will add and remove mapping macros here.
// DO NOT EDIT what you see in these blocks of generated code!
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CShapesApp construction
CShapesApp::CShapesApp()
// TODO: add construction code here,
// Place all significant initialization in InitInstance
// The one and only CShapesApp object
CShapesApp theApp;
// compute unit length axis vectors from an angle
static void compute_axis_vectors (
real angle, // I: angle defining the x axis
p_2d v_x, // O: x unit vector
p_2d v_y) // O: y unit vector
vec (cos (angle), sin(angle), v_x);
vec (-v_x[Y], v_x[X], v_y);
and so on...
// Purpose: main function
static void chook_main (void)
boolean show_dialog;
short f_key;
Cshapedlg dlg;
// Enable use of the MFC dynamically linked libraries
AFX_MANAGE_STATE( AfxGetStaticModuleState() );
show_dialog = TRUE;
undo_hold();
while (TRUE)
if (show_dialog)
if (dlg.DoModal() == IDOK) // run the dialog
create_shape (dlg.m_create_n, dlg.m_shape_n,
dlg.m_width, dlg.m_height, dlg.m_angle * D2R,
dlg.m_create_point);
else // Cancel
break;
cleartextall();
menu (TEXT_HDR, MENU_1); // Display the Option / Create menu
f_command (&f_key, 1); // Get user's selection
if (f_key != 1)
break;
// Purpose: Entry point for C-Hooks programs
extern "C" void CH_ENTRY m_main (long *ptrs)
if (open_app (ptrs))
chook_main();
close_app (ptrs);
While I was pasting this code for you, I was also trying to rebuild Shapes.dll, and it worked. I don't know how that happened. Anyway, I now get an error --
"Debug Assertion failed"
File: afxwin1.inl, line 22
when I try to run the debug version of Shapes.dll in MasterCAM. And ofcourse, I get many linker errors when trying to build a release version.
PLease let me know if any of this makes sense to you. Thank you, I appreciate your help.
Ok, let's be certain of a few things...
Are you using MSVC6.0 or a .NET version?
Did you create your C-Hook project with the MF App Wizard (Dll)?
Let's just worry about the Release build for now (distrubting debug version of the MFC and VCRT DLLs isn't fun). Do your Project Settings look similar to this (MSVC6.0)?
Warning level 4 is just a habit of mine, so the default of 3 is fine.
I use this for preprocessor defs:
WIN32,NDEBUG,_WINDOWS,_WINDLL,_AFXDLL,_MBCS,_USRDLL,_MSVC_,MSWINDOWS
Your path to the SDK will be different, obviously.
Using MSVC++ 6.0
Created a single project with the MFC AppWizard DLL (as an extension DLL though ). I have commented out the code that comes with the "extension DLL".
My project settings look similar, except that I had _AFXEXT added to preprocessor defs. I got rid of that and tried to rebuild release DLL and got similar results (29 errors).
[if I choose to ignore the "Debug Assertion failed" error in MasterCAM, the Shapes dialog box does pop up and I can create shapes]
I commented out the following code
static AFX_EXTENSION_MODULE ShapesDLL = { NULL, NULL };
extern "C" int APIENTRY
DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved)
// Remove this if you use lpReserved
UNREFERENCED_PARAMETER(lpReserved);
if (dwReason == DLL_PROCESS_ATTACH)
TRACE0("SHAPES.DLL Initializing!n");
// Extension DLL one-time initialization
if (!AfxInitExtensionModule(ShapesDLL, hInstance))
return 0;
// Insert this DLL into the resource chain
// NOTE: If this Extension DLL is being implicitly linked to by
// an MFC Regular DLL (such as an ActiveX Control)
// instead of an MFC application, then you will want to
// remove this line from DllMain and put it in a separate
// function exported from this Extension DLL. The Regular DLL
// that uses this Extension DLL should then explicitly call that
// function to initialize this Extension DLL. Otherwise,
// the CDynLinkLibrary object will not be attached to the
// Regular DLL's resource chain, and serious problems will
// result.
new CDynLinkLibrary(ShapesDLL);
else if (dwReason == DLL_PROCESS_DETACH)
TRACE0("SHAPES.DLL Terminating!n");
// Terminate the library before destructors are called
AfxTermExtensionModule(ShapesDLL);
return 1; // ok
And added this code mentioned in the Shapes.cpp example:
// Note!
// If this DLL is dynamically linked against the MFC
// DLLs, any functions exported from this DLL which
// call into MFC must have the AFX_MANAGE_STATE macro
// added at the very beginning of the function.
// For example:
// extern "C" BOOL PASCAL EXPORT ExportedFunction()
// AFX_MANAGE_STATE(AfxGetStaticModuleState());
// // normal function body here
// It is very important that this macro appear in each
// function, prior to any calls into MFC. This means that
// it must appear as the first statement within the
// function, even before any object variable declarations
// as their constructors may generate calls into the MFC
// DLL.
// Please see MFC Technical Notes 33 and 58 for additional
// details.
// CShapesApp
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
CShapesApp theApp;
return 0;
// result.
return 1; // ok
// Note!
// For example:
// DLL.
// details.
// CShapesApp
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
CShapesApp theApp;
I would allow the MFC App Wizard (DLL) to create a regular DLL that uses the shared MFC DLLs.
return 0;
// result.
return 1; // ok
Right. This code is generated when creating an extension DLL. C-Hooks aren't MFC extensions. The main class for the C-Hook isn't generated, either (something that the App Wizard will do with regular DLLs).
I was finally able to make a release DLL version without any errors or warnings. I had ignored a few libraries (MSVCRT, mfcs42d.lib) in the project settings while debugging the code. I got rid of that, and everything is working fine now.
Thanks for your help.
MRB.
