XP, word 2003, and .EMF files
We've had 3 machines upgraded, with windows XP and word 2003. Now a problem has cropped up, the VB script doc sheet I wrote is supposed to put a .EMF file of the part at the bottom of the sheet.
However, with this combination, the .EMF file in the text box is solid black. Any ideas what may be causing this?
John
I take that back. Forgot to make a slight change in the code, went back and did it. I don't get an image at all now, just a blank box with a cursor. The bitmap file isn't being written (its a .bmp file, right?)
FWIW, heres the code that does the graphic and puts it into word:
'Load Graphic into textbox
graphic="c:temptest.emf" <--replaced with .bmp
DoMetafile graphic <---replaced with DoBitmapFile
.Selection.ShapeRange.Select
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 115, _
480, 390, 302).Select
.Selection.ShapeRange.TextFrame.TextRange.Select
.Selection.Collapse
.Selection.ShapeRange.Line.Visible = msoFalse
.Selection.InlineShapes.AddPicture graphic,False,True
HAH! shoulda done this first...did some searching on the forums, and made this modification...
Call SetBackGroundColor(mcCOLOR_WHITE)
Call RepaintScreen(True)
DoMetafile graphic
.Selection.Collapse
Call SetBackGroundColor(mcCOLOR_BLACK)
Works now! also tried the open GL off (already was) and turning down hardware acceleration. neither worked!
John
Hi John,
I came up to WI a while ago, and Jake gave us a copy of your script to use in NC. We were having the same problem w/ 2 of our shop computers and I couldn't figure it out. I'm going to try doing what your last post says and see if that helps. We could get a correct image if the screen backgound was set to white. I'll write back and let you know what happens.
Dennis Archer
