VBScript question R/E all levels on
Mr Mick and Mr Bulliness
Many thanks guys for all the help and advice you have allready offered to this novice VBScripter. If you have any insights that could help steer me in a more productive direction they would be greatly appreaciated
I would like to modify this script to run automatically. Parsing through the database, gleaning each subisquent 360. or -360. deg arc automatically. And at the end of the search turn all levels back on.
My first big mess is that when I turn all levels on the screen blinks on and off 256 times. Is there a better way to set all levels on without a screen regen for each level/
Second do you see a simple way to search the database selecting the next succesive diameter?
Thanks for all the help you have given me despite the fact you have more profitable endeavors to persue.
Charlie.
' SEARCH ARCS BY DIAMETER
' CBLYTHE3D
' Modified mcMick code
' This little puppy makes short work of sorting holes to layers
' by diameter. I would have liked to automatically set succesive
' level numbers and use the diameter as the name.
' While it works fine the coding is a really sloppy mess
' but meets the imediate need Any help would be appreciated
Const DEF_CURRENT_ENTITY = -1
Const DEF_NEW_GROUP = " Arcs"
Public Const DEF_NOTEPAD = "C:WindowsNotepad.exe"
Public Const DEF_NOTEPAD_NT = "C:WINNTNotepad.exe"
Public Const DEF_LIST = "mcLevelList.txt"
Public Const DEF_ALL_LEVELS = 24
' -- Start Script
'Call Main
Call SearchArcsByDiameter
Call LevList()
' Sub Declaration
Sub SearchArcsByDiameter()
Dim CArc, CNewArc
Dim bRet, intCounter
Dim cRet
Dim dblExistingArcs
Dim newLevel
Dim intPoints
Dim CPoint
Dim objSelectedArc
Call askLevel(newLevel)
cRet=1
Do While cRet=1
Select Case askYesNoCancel("Shall We Procede?")
Case mcMSG_CANCEL
' -- Bail...
Exit Sub
Case mcMSG_NO
Exit Sub
Case mcMSG_YES
' -- Procede
End Select
newLevel = (newLevel + 1)
If AskForEntity ("Select arc diameter", 7) Then
Set objSelectedArc = New McAr
' -- Get the properties of the selected arc
bRet = GetArcData(DEF_CURRENT_ENTITY, objSelectedArc)
dblExistingArcs = (objSelectedArc.r *2)
' -- Prompt for new dia
If dblExistingArcs = 0 Then
Exit Sub
End If
If SetLevelVisibleByNumber(newLevel, False) Then
End If
' -- Initialize counter
intCounter = 0
bRet = StartDBSearch(mc_alive, mc_arctype)
' -- Begin loop through database
Do While bRet
Set CArc = New McAr
' -- Get this entity
If GetArcData(DEF_CURRENT_ENTITY,CArc) Then
' -- Test
If Round((CArc.R * 2),3 ) = Round( dblExistingArcs, 3 ) Then
If CArc.SW = 360 Or cArc.sw = -360 Then
SetEntityLevel(newLevel)
SetEntityColor(newLevel)
If SetLevelName(newlevel,Round(dblExistingArcs, 3))Then
Else
' -- Keep a running total
intCounter = intCounter + 1
' -- Get this arc properties
If GetArcData(GetEntityEptr, CArc) Then
Set CPoint = New McPt
' -- Assign this arcs location for the new point
With CPoint
.X = CArc.X
.Y = CArc.Y
.Z = CArc.Z
End With
' -- Create the point
If CreatePoint(CPoint,7, newLevel) = mcENTITY_INVALID Then
' -- Failed to create point....
Else
' -- Keeping score
AddCurrentEntToGroup(Round(dblExistingArcs, 3))
intPoints = intPoints + 1
End If
End If
End If
End If
Else
End If
End If
bRet = NextDBSearch
Loop
If intCounter = 0 Then
ShowString "No matching arcs found"
Else
ShowString intCounter & " " & dblExistingArcs & " arcs processed"
End If
End If
Loop
End Sub
' -- Start Script
' Sub Declaration
Sub LevList()
Dim intCurrentLevel, strCurrentLevelName()
Dim FSO, fsoLevelsList, intCount, strTemp, strShell
intCount = -1
' -- Iterate all levels
For intCurrentLevel = 1 To DEF_ALL_LEVELS
strTemp = Trim(GetLevelName(intCurrentLevel))
' -- Is this level named?
If Len(strTemp) <> 0 Then
' -- Resize our array
intCount = intCount + 1
ReDim Preserve strCurrentLevelName(intCount)
' -- Assign level name and nunber
strCurrentLevelName(intCount) = "Level #" & intCurrentLevel & " = " & strTemp
End If
Next
' -- Test
If intCount = -1 Then
' -- No named levels found
ShowString "No named levels found in current drawing"
Else
Set FSO = CreateObject("Scripting.FileSystemObject")
Set fsoLevelsList = FSO.CreateTextFile(GetPathOfThisScript & DEF_LIST)
For intCurrentLevel = 0 To intCount
fsoLevelsList.WriteLine strCurrentLevelName(intCurrentLevel)
Next
fsoLevelsList.Close
' -- Where is Notepad?
If FSO.FileExists(DEF_NOTEPAD) Then
strShell = DEF_NOTEPAD
ElseIf FSO.FileExists(DEF_NOTEPAD_NT) > 0 Then
strShell = DEF_NOTEPAD_NT
Else
strShell = vbNullString
End If
' -- Are we ok?
If Len(strShell) = 0 Then
'EditFile GetPathOfThisScript & "mcLevelList.txt"
' -- Stays modal to mc
Else
' -- Ok, show the file
strShell = strShell & " " & GetPathOfThisScript & DEF_LIST
Call ShellAndWait (strShell, False)
End If
' -- Clean up
Erase strCurrentLevelName
End If
' -- Clean up
Set FSO = Nothing
Set fsoLevelsList = Nothing
End Sub
oops Forgot to include this problamatic script
Public Const DEF_ALL_LEVELS = 255
' -- Start Script
Call LvAllOn()
' Sub Declaration
Sub LvAllOn()
For intCurrentLevel = 1 To 255
Call SetLevelVisibleByNumber(intCurrentLevel, 1)
Next
End Sub
Thanks again guys
I don't notice this problem in X. I wonder if it was a bug in 9.x.
I don't have much time at the moment to code up a sample, but I did write something a while back that I think is along the same lines as what you're looking for. A good idea would be to discover all differing diameters and store them in a Dictionary object (which is basically just a hash table/associative array). Then you could iterate through your Dictionary and assign levels to each diameter. Take a look at my Z_Colours.vbs script in the VB_Script directory on the FTP site. I'm setting the colour of entities at each unique depth. So, for example, all entities at -4Z are blue, all entities at 3.25Z are green, etc. This is probably somewhat similar to what you're looking for and could easily be modifed to set level based on arc diameter instead of colour based on Z value.
