X NC Path (C-Hook Question)
How would I be able to programatically determine the path of the NC directory? In previous versions, that was handled by the nc_prefix variable. That doesn't appear to be available in X.
The closest thing I've seen is the szNcPath in the file_ctrl structure? But obviously I can't create a new file_ctrl variable since its szNCPath will be empty (or some random memory address). Perhaps something else has a pointer to an existing file_ctrl structure?
If worse comes to worse, I can assemble the path myself based on the install directory and whether the user is running Mill/Lathe/Router but I haven't found a way in that big CHM to determine even that, yet.
Chris,
There may be other ways (even simpler ways), but this works for me ->
Here is a seriously snipped code sample.
GetData() loops thru all the operations in the Toolpath Manager and calls GrpData() to gather up data on each Machine Group.
// Gather data about the operation
bool GrpData(op_list *opl)
if (opl == NULL) { return false; }
char ncSuffix[_MAX_EXT] = "";
char ncPrefix[_MAX_PATH] = "";
group_list *gpl = OMgetOpMachineGroup(opl->op.op_idn, FALSE);
if (gpl == NULL) { return false; }
// if (gpl->name) has changed from last time, we're into a NEW Machine Group
CCNCMachine *pMachine = new CCNCMachine(gpl, FALSE, FALSE);
if (pMachine == NULL) { return false; } // Oops!
strcpy (ncPrefix, pMachine->NCPrefix()); // save for later
strcpy (ncSuffix, pMachine->NCSuffix()); // save for later
// -- snip --
return true;
// Loop thru all the operations
bool GetData()
op_list *opl = op_list_ptr;
while (opl != NULL)
bOK = GrpData(opl);
if (!bOK) { break; }
opl = opl->next_ptr;
return bOK;
