How to get info on machine groups and operations from the SDK.
Hi everyone,
I have the following SDK questions:
1. Each operation listed in the toolpath manager has a description associated with it. How do I access these descriptions from the SDK?
2. To get a list of all operations in the current model, I can call
list_manager(OP_ID, "", LSTMGR_GET, (void **)&operaThis);
How can I get a list of all machine groups in the current model?
3. How can I tell which machine group an operation is associated with or how can I get a list of all the operations associated with a machine group?
4. How do I access the description of a machine group
Thanks in advance.
CaKiwi
I'm assuming you're asking about op.comment.
Looks like the list_manager() function isn't used to get machine group data in X. I haven't played with the groups in X yet, so I'm of no help here. Did you find anything in Groups_CH.h that might help? I'm also of little help for questions 3 and 4. Hopefully someone else can help.
Hi Bullines,
Thanks for the response.
I had looked at op.comment but it does not seem to hold the description of the operation. For example, if I load the sample part contour-shallow - add cuts.mcx, it has 3 operations shown in the Operations Manager each of which has a description associated with it ("Without - Shallow", "Shallow - Add Cuts" and Alt - Floor Toolpath"). But the op.comment field for each is empty.
I will look some more in groups_ch.h to see what I can find for my machine group questions.
Thanks again.
CaKiwi
The only thing I have come up with so far is the grp_idn field in the cmn structure of the op structure of the op_list structure. I have a model with 2 machine groups, the first containing 3 operations and the second containing 1 operation. When I step through the operation list, the grp_idn field has values 2, 3, 4 and 6 respectively for each of the 4 operations. I am surmising that the 2 machine groups are in slots 1 and 5 and that when this number jumps by 2 we have started a new machine group. If this is all true (I need to try it out on a few more models), I at least know which operations are in which machine groups. If anyone has any better ideas, I would love to hear from them.
I've found that if I call the routine GroupsMachineGroup with a NULL argument I get an arbitrary member of a list containing all the machine groups and operations and I can then get to the head of the list by following the head_ptr of this member. Calling it with a member of that list returns the machine group of that member. The following code finds the machine groups in the list.
int idn;
group_list *pGroup1, *pGroup2;
pGroup1 = GroupsMachineGroup (NULL);
pGroup1 = pGroup1->head_ptr;
//printf("%s - %s", pGroup1->name, pGroup1->ogi.pg1.comment);
idn = pGroup1->grp_idn;
pGroup2 = pGroup1->next_ptr;
while (pGroup2 != NULL)
do
pGroup2 = pGroup2->next_ptr;
if (pGroup2 == NULL)
break;
pGroup1 = GroupsMachineGroup (pGroup2);
} while (idn == pGroup1->grp_idn);
if (pGroup2 != NULL)
I've also found a routine GetMachineList() but I've had a problem linking with it. I'll let you know if this provides a simpler solution.
  • 2 months later...
