More SDK Questions
1. I am trying to run a post processor from a nethook and it seems like the routine I need to use is run_post_exe_dll(), but the documentation is a bit vague as to what arguments I need to give it. I have retrieved what seems to be the post processor name using PostProcFileStr() but I need to know what to put in the other 3 arguments.
2. I want to write a solid to an STL file but calling wr_stl() gets a fatal error. Does anyone have any experience using this?
Thanks for any assistance anyone can provide.
With versions prior to X, it was pretty straight-forward. run_post_exe_dll() took four parameters; post EXE filename, NCI filename, PST filename and NC filename.
But in the X SDK documentation, you're right. It's not helpful at all. So maybe it's the same as it was in previous versions (assuming that the new CD/MD stuff doesn't change things)? But indeed, as you've found out, if you're not familiar with the previous SDKs, the documentation makes absolutely no sense. Take what you will from "string passing in parameter #1 to the post", "string passing in parameter #2 to the post" and "string passing in parameter #3 to the post" eek.gif
Bullines,
Thanks for the response. I did find a variable called post_args[3][FILENAME_MAX] but unfortunately it only contains zero length strings. Where do I get the 3 filenames from? Are they provided in the SDK or do I need to provide them? I found 2 routines NCIFile() and NCFile() in the documentation which sound as though they return the filenames but I cannot find them anywhere in the SDK libraries.
Thanks again.
Prior to X, the other three variables that you could use were nc_filename, nc_filename, and mpost_filename. And of course, you could override those with your own paths.
But in X, I have no idea where it is. CD/MD has changed how it all works. Searching the CHM of the X SDK documentation for something like "NC filename" yields a few different possibilities. Maybe somebody from CNC Software can give some insight? confused.gif
Wish I'd seen this thread earlier. Wouldn't have wanted to leave you hanging this long. You need to include the machine def header
#include "m_core.h"
#include "m_post.h"
#include "m_machinedef.h"
which is where the nci paths come from. There's some functions in there that reference the machine def to get these values. CaKiwi (Calafornia Kiwi? Like the fruit?) seems to have found two of them. Bullines's comment about the order of arguments is correct.
In any case, the call ends up looking like this.
//strMpPath is local, please substitute MP.DLL path
run_post_exe_dll (strMpPath.GetBuffer(0), NCIFile().GetBuffer(0),
PostProcFile().GetBuffer(0), NCFile().GetBuffer(0));
You don't actually need to touch the post_args[3][FILENAME_MAX] variables.
Happy Coding
___________________________
Jon Griffin
Software Engineer
CNC Software
Jon,
Thanks for the reply. I'm getting an unresolved symbol when I link with NCIFile(). I assume it has something to do with name decoration and that I need to set some option in my project. Any help you could give would be greatly appreciated.
CaKiwi (California Kiwi, like the person from New Zealand)
The function is in MCMachineDef.lib. Runiing the MSVC utility depends on MCMachineDef.dll shows it as:
?NCIFile@@YAAAV?$CStringT@DV?$StrTraitMFC_DLL@DV?$ChTraitsCRT@D@ATL@@@@@ATL@@PAU_group_list@@PAD11@Z
I don't know what all that means but maybe it will mean something to you
This is a common problem for new chooks. You need to make sure you have the .lib file included, then go back and make sure that you have both the debug and release versions of it, each excluded from each others builds. This should clear up your issue.
Also, you need to #include (it's MFC) if you haven't already, to get access to CString.
Jon Griffin
Software Engineer
CNC Software
I fixed the unresolved symbols by upgrading to VS .NET. I was using VS 6.0 (despite the fact that the documentation plainly states that it is no longer supported).
Now that I am running the post successfully, my next question is how can I set the post processing options, such as not editing the NC file when the post completes.
I have been led to believe the routines I need to get and set the post processing options are GetPostSetting() and SetPostSettings(). My knowledge of C++ is limited and I am having trouble calling them. If I do it like this
post_dlg_settings pds;
CCNCControl::GetPostSettings(&pds);
I get a syntax error
c:TempTest.cpp(154): error C2352: 'CCNCControl::GetPostSettings' : illegal call of non-static member function
CCNCControl c1;
c1.GetPostSettings(&pds);
it compiles and runs, but the data returned is uninitialized. Any help would be greatly appreciated.
