Mastercam VBS with Open Office
Managment has asked me if I could convert my VBS setup sheet to run with open office ("becauses its free!") instead of Word that I wrote it for. From what I have been able to determine, OO doesn't use VBS.
I'd like to hear from anyone else more experienced with programming scripts to confirm or deny this.
Anyone?
John
Sorry about that John. After re-reading your question and my post, I realized that I read it waaay wrong. Maybe it was too early in the AM, but I thought you were asking about OpenOffice's equivalent to Microsoft Office's VBA. My bad bonk.gif
Yes, you can automate OOo from Mastercam using COM much like you would with MS Office. The syntax and some other things aren't the same, but it's very similar. Here's a quick snippet that I whipped up that hopefully will get you started. All it does is write some text in a Writer document and save it with the sane name and dir as your current MC9 file (Ex: C:Stuff1234.mc9 -> C:Stuff1234.sxw):
'// Author: Chris Bellini [email protected]
'// Copyright © 2005 In-House Solutions Inc.
'// Date: 06/03/2005 11:10 AM
'// File Name: mcam_OOo.vbs
'// Description: an example of automating OpenOffice.org Writer from Mastercam
'// Comments:
'// - 06/03/2005 <cvb>: initial version
'// This library is free software; you can redistribute it and/or
'// modify it under the terms of the GNU Lesser General Public
'// License as published by the Free Software Foundation; either
'// version 2.1 of the License, or (at your option) any later version.
'// This library is distributed in the hope that it will be useful,
'// but WITHOUT ANY WARRANTY; without even the implied warranty of
'// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
'// Lesser General Public License for more details.
'// You should have received a copy of the GNU Lesser General Public
'// License along with this library; if not, visit
or write to the Free Software
'// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
'// MA 02110-1301, USA
' ////////// CONSTANTS ////////////////
Const DEF_SXW_EXT = ".sxw" ' OOo Writer file extension
' Call the main subroutine
Call Main()
' Purpose: The main subroutine
Sub Main()
Dim args() ' empty arguments
Dim objOODesktop ' OOo Desktop object
Dim objOODocument ' OOo Document object
Dim objOOText ' OOo Text object
Dim objOOCursor ' OOo Cursor object
Dim strCurrPath ' current path to our MC9 file
Dim strBName ' the base of the filename of our MC9 file
Dim strSXWFileName : strSXWFileName = "C:FromMC.sxw" ' assembled SXW filename
' The service manager is always the starting point
' If there is no office running then an office is started up
Set objServiceManager = CreateObject("com.sun.star.ServiceManager")
' Create the Desktop
Set objOODesktop = objServiceManager.createInstance("com.sun.star.frame.Desktop")
' Open a new empty Writer document
Set objOODocument = objOODesktop.loadComponentFromURL("private:factory/swriter",_
"_blank", 0, args)
' Create a text object
Set objOOText = objOODocument.getText
' Create a cursor object
Set objOOCursor = objOOText.createTextCursor
' Insert some text
objOOText.insertString objOOCursor, "Greetings from Mastercam VBS!" & vbLf, False
' If we have a valid MC9 file loaded, let's use its directory and name
' as the base for the filename of our SXW file. Otherwise, just use our
' default of FromMC.sxw.
If (IsDrawing()) Then
' get the current path
strCurrPath = objFSO.GetParentFolderName(GetCurrentFileName())
' get the base
strBName = objFSO.GetBaseName(GetCurrentFileName()
' assemble the filename of our SXW file
strSXWFileName = strCurrPath & "" & strBName & DEF_SXW_EXT
End If
' Save the file
Call objOODocument.storeAsURL (ConvertToURL(strSXWFileName), args)
' All done
ShowString ("Saved the file to: " & strSXWFileName)
End Sub
' Purpose: Convert a standard Windows path to a OOo file URL
' I: Windows file path
' O: OpenOffice file URL
Function ConvertToUrl(strFile)
strFile = Replace(strFile, "", "/")
strFile = Replace(strFile, ":", "|")
strFile = Replace(strFile, " ", "%20")
strFile = "file:///" + strFile
ConvertToUrl = strFile
End Function
' Purpose: Determine if something with geo is open in MC.
' I: (none)
' O: True=has geo, False=empty file
Function IsDrawing()
Dim bRet ' return value
' try to find an alive entity
bRet = StartDBSearch(mc_alive, -1)
' return
IsDrawing = bRet
End Function
I guess I'm just looking for a easy fix to convert my VBS file from Word output to OO, but I guess it'll be more work than I really want to put into it. It took me several weeks to do, mostly cause I had to learn scripting and had lots of help from some great folks on this forum.
FWIW, the VBS file I wrote is in the FTP, setupsheet.vbs I believe.
John
