Question of WCS in vb
You can run the view manager with this:
Call RunMastercamCommand("namview")
but that's it, as far as I know. All of the functions that you can run directly are located in your Mastercam EXEs accompanying text file. So if you're running Mill, look in Mill9.txt for a section called "(function name: description [maximum length: 8:30]"...it should be near the 2830th line of the file.
Here is the entire Mill list
9000. "12345678: 123456789012345678901234567890"
9001. "zoom: Screen-Zoom" _
9002. "unzoom: Screen-Unzoom" _
9003. "repaint: Screen-Repaint" _
9004. "analyze: Analyze" _
9005. "delete: Delete" _
9006. "file: File" _
9007. "modify: Modify" _
9008. "create: Create" _
9009. "dispinfo: Screen-Display info" _
9010. "help: Help" _
9011. "fit: Screen-Fit" _
9012. "unzoom8: Screen-Unzoom by 0.8" _
9013. "curpos: Cursor Tracking (Toggle)" _
9014. "delwndw: Delete-Window" _
9015. "editfile: File-Edit" _
9016. "blank: Screen-Blank" _
9017. "config: Screen-Configure" _
9018. "drwaxes: Screen-Draw axes" _
9019. "rundll: Execute C-Hook" _
9020. "draftpm: Draft-Globals" _
9021. "font: Menu Font" _
9022. "" _
9023. "mmalloc: List Memory" _
9024. "mfile: List Files" _
9025. "undo: Undo" _
9026. "surfdisp: Screen-Surf Disp" _
9027. "drawnc: Screen-Draw Toolpath" _
9028. "vwports: Screen-Viewports" _
9029. "version: Version" _
9030. "xform: Xform" _
9031. "autosave: File-AutoSave" _
9032. "group: Groups" _
9033. "chgcolrs: Screen-Change Colors" _
9034. "chglevs: Screen-Change Levels" _
9035. "autocl: Automatic Centerlines" _
9036. "color: Main Color" _
9037. "level: Levels-Main" _
9038. "mask: Levels-Mask" _
9039. "tplane: Tplane" _
9040. "cplane: Cplane" _
9041. "gview: Gview" _
9042. "zdepth: Cplane-Depth" _
9043. "levdlg: Levels-Dialog" _
9044. "vislev: Levels-Visible" _
9045. "toolbar: Toolbar Visible (Toggle)" _
9046. "dbstats: Screen-Statistics" _
9047. "endpts: Screen-Endpoints" _
9048. "clrcolrs: Screen-Clear Colors" _
9049. "shade: Screen-Surf Disp-Shading" _
9050. "crpoint: Create-Point" _
9051. "crptpos: Create-Point-Position" _
9052. "ptalong: Create-Point-Along Entity" _
9053. "nodepts: Create-Point-Node Points" _
9054. "ctrlpts: Create-Point-Cpts NURBS" _
9055. "ptdynmic: Create-Point-Dynamic" _
9056. "crptlen: Create-Point-Length" _
9057. "ptsrfprj: Create-Point-Surface Project" _
9058. "crline: Create-Line" _
9059. "clhorz: Create-Line-Horizontal" _
9060. "clvert: Create-Line-Vertical" _
9061. "clepts: Create-Line-Endpoints" _
9062. "clmulti: Create-Line-Multi" _
9063. "clpolar: Create-Line-Polar" _
9064. "cltan: Create-Line-Tangent" _
9065. "cltanang: Create-Line-Tangent-Angle" _
9066. "cltan2a: Create-Line-Tangent-2 Arcs" _
9067. "cltanpt: Create-Line-Tangent-Point" _
9068. "clperp: Create-Line-Perpendicular" _
9069. "clparal: Create-Line-Parallel" _
9070. "crarc: Create-Arc" _
9071. "capolar: Create-Arc-Polar" _
9072. "cactrpt: Create-Arc-Polar-Center Point" _
9073. "casktch: Create-Arc-Polar-Sketch" _
9074. "castart: Create-Arc-Polar-Start Point" _
9075. "caend: Create-Arc-Polar-End Point" _
9076. "caepts: Create-Arc-Endpoints" _
9077. "ca3pts: Create-Arc-3 points" _
9078. "catan: Create-Arc-Tangent" _
9079. "catan1: Create-Arc-Tangent-1 Entity" _
9080. "catan3: Create-Arc-Tangent-3 Entities" _
9081. "catanpt: Create-Arc-Tangent-Point" _
9082. "ca2ptcir: Create-Circle-2 Points" _
9083. "ca3ptcir: Create-Circle-3 Points" _
9084. "captrad: Create-Circle-Point/Radius" _
9085. "captdia: Create-Circle-Point/Diameter" _
9086. "captedge: Create-Circle-Point/Edge" _
9087. "crfillet: Create-Fillet" _
9088. "crspline: Create-Spline" _
9089. "crcurve: Create-Curve" _
9090. "ellipse: Create-Ellipse" _
9091. "ccconst: Create-Curve-Const Parameter" _
9092. "ccedge: Create-Curve-One Edge" _
9093. "ccinter: Create-Curve-Intersect" _
9094. "ccpatch: Create-Curve-Patch Boundaries" _
9095. "ccflow: Create-Curve-Flowline" _
9096. "ccproj: Create-Curve-Project" _
9097. "ccdynmic: Create-Curve-Dynamic" _
9098. "ccpart: Create-Curve-Parting Line" _
9099. "crsurf: Create-Surface" _
9100. "csloft: Create-Surface-Loft" _
9101. "cscoons: Create-Surface-Coons" _
9102. "csruled: Create-Surface-Ruled" _
9103. "csrev: Create-Surface-Revolved" _
9104. "csswept: Create-Surface-Swept" _
9105. "csdraft: Create-Surface-Draft" _
9106. "csfillet: Create-Surface-Fillet" _
9107. "csofst: Create-Surface-Offset" _
9108. "cstrim: Create-Surface-Trim" _
9109. "csblend: Create-Surface-2 Surface Blend"_
9110. "crrec: Create-Rectangle" _
9111. "rec1pt: Create-Rectangle-1 Point" _
9112. "rec2pts: Create-Rectangle-2 Points" _
9113. "crdraft: Create-Drafting" _
9114. "cddim: Create-Drafting-Dimension" _
9115. "crnote: Create-Drafting-Note" _
9116. "crlabel: Create-Drafting-Label" _
9117. "crleader: Create-Drafting-Leader" _
9118. "crwit: Create-Drafting-Witness Line" _
9119. "eddraft: Create-Drafting-Multi edit" _
9120. "crhatch: Create-Drafting-Hatch" _
9121. "chamfer: Create-Chamfer" _
9122. "crlets: Create-Letters" _
9123. "pattern: Create-Pattern" _
9124. "anzpt: Analyze-Point" _
9125. "anzonly: Analyze-Only" _
9126. "anzbpts: Analyze-Between points" _
9127. "anzang: Analyze-Angle" _
9128. "anzdynm: Analyze-Dynamic" _
9129. "anzarea: Analyze-Area Calculations" _
9130. "eamod: Entity Attributes (Apply)" _
9131. "anzscurv: Analyze-Surfaces-Curvature" _
9132. "anznorm: Analyze-Surfaces-Test Normals" _
9133. "anzbase: Analyze-Surfaces-Base Surfs" _
9134. "delchain: Delete-Chain" _
9135. "deldup: Delete-Duplicate" _
9136. "delonly: Delete-Only" _
9137. "delall: Delete-All" _
9138. "delgrp: Delete-Group" _
9139. "delreslt: Delete-Result" _
9140. "crptperp: Create-Point-Perpendicular" _
9141. "crptcirc: Create-Point-Small Circles _
9142. "undelete: Delete-Undelete" _
9143. " " _
9144. "filemrg: File-Merge" _
9145. "filesave: File-Save" _
9146. "fileget: File-Get" _
9147. "hardcopy: File-Hardcopy" _
9148. "browse: File-Browse" _
9149. "communic: File-Communications" _
9150. "convert: File-Convert" _
9151. "ascii: File-Convert-ASCII" _
9152. "cadl: File-Convert-CADL" _
9153. "dxf: File-Convert-DXF (pre-V9)" _
9154. "iges: File-Convert-IGES" _
9155. "vda: File-Convert-VDA" _
9156. " " _
9157. "renumber: File-Renumber" _
9158. " " _
9159. "shell: File-DOS Shell" _
9160. "levelrep: Levels-Report" _
9161. "trim: Modify-Trim" _
9162. "trim1: Modify-Trim-1 Entity" _
9163. "trim2: Modify-Trim-2 Entities" _
9164. "trim3: Modify-Trim-3 Entities" _
9165. "trim2pt: Modify-Trim-To Point" _
9166. "trimmany: Modify-Trim-Many" _
9167. "closearc: Modify-Trim-Close Arc" _
9168. "divide: Modify-Trim-Divide" _
9169. "break: Modify-Break" _
9170. "brkarcs: Modify-Break-Arcs" _
9171. "brkmany: Modify-Break-Many Pieces" _
9172. "brk2pcs: Modify-Break-2 Pieces" _
9173. "brklen: Modify-Break-At Length" _
9174. "brknote: Modify-Break-Draft/Line" _
9175. "brkhatch: Modify-Break-Hatch/Line" _
9176. "brkcdata: Modify-Break-Cdata/Line" _
9177. "join: Modify-Join" _
9178. "modnorm: Modify-Normal" _
9179. "modnbs: Modify-Cpts NBS" _
9180. "x2nbs: Modify-X to NBS" _
9181. "extend: Modify-Extend" _
9182. "drag: Modify-Drag" _
9183. "scrnctr: Screen-Center" _
9184. "initscrn: File-New" _
9185. "combvws: Screen-Combine Views" _
9186. "plot: Screen-Plot" _
9187. "xfmmir: Xform-Mirror" _
9188. "xfmrot: Xform-Rotate" _
9189. "xfmscale: Xform-Scale" _
9190. "xfmsqsh: Xform-Squash" _
9191. "xfmtrans: Xform-Translate" _
9192. "xfmofst: Xform-Offset" _
9193. "xfmoctr: Xform-Offset Contour" _
9194. "tpmenu: Toolpaths" _
9195. "contour: Toolpaths-Contour" _
9196. "drill: Toolpaths-Drill" _
9197. "pocket: Toolpaths-Pocket" _
9198. "ncflow: Toolpaths-Flowline" _
9199. "ncmsurf: Toolpaths-Surface" _
9200. "ncproj: Toolpaths-Project" _
9201. "nctrim: Toolpaths-Trim" _
9202. "***** not used *****" _
9203. "nccoons: Toolpaths-Coons" _
9204. "ncruled: Toolpaths-Ruled" _
9205. "ncswept: Toolpaths-Swept" _
9206. "ncrev: Toolpaths-Revolution" _
9207. "***** not used *****" _
9208. "manent: Toolpaths-Manual Entry" _
9209. "ncpoint: Toolpaths-Point" _
9210. "***** wire *****" _
9211. "ncutils: NC Utils" _
9212. "actour: Analyze-Contour" _
9213. "backplot: NC Utils-Backplot" _
9214. "***** not used *****" _
9215. "filter: NC Utils-Filter" _
9216. "pstmenu: NC Utils-Post" _
9217. "pstchg: NC Utils-Post-Change" _
9218. "pstrun: NC Utils-Post-Run" _
9219. "pstrev: NC Utils-Post-Reverse" _
9220. "deftls: NC Utils-Define Tools" _
9221. "setsht: NC Utils-Setup Sheet" _
9222. "***** not used *****" _
9223. "exefunc: Execute Function" _
9224. "prompt: Prompt Visible (Toggle)" _
9225. "gvtop: Gview-Top" _
9226. "gvfront: Gview-Front" _
9227. "gvside: Gview-Side" _
9228. "gviso: Gview-Isometric" _
9229. "gvnum: Gview-Number" _
9230. "gvlast: Gview-Last" _
9231. "gvent: Gview-Entity" _
9232. "gvrot: Gview-Rotate" _
9233. "gvmouse: Gview-Mouse" _
9234. "gvdymic: Gview-Dynamic" _
9235. "cporgn: Cplane-Origin" _
9236. "cp3d: Cplane-3D" _
9237. "cptop: Cplane-Top" _
9238. "cpfrnt: Cplane-Front" _
9239. "cpside: Cplane-Side" _
9240. "cpnum: Cplane-Number" _
9241. "cplast: Cplane-Last" _
9242. "cpent: Cplane-Entity" _
9243. "cprot: Cplane-Rotate" _
9244. "cpnorm: Cplane-Normal" _
9245. "cpmouse: Cplane-Mouse" _
9246. "cppxz: Cplane-XZ(+)" _
9247. "cpnxz: Cplane-XZ(-)" _
9248. "cppdz: Cplane-DZ(+)" _
9249. "cpndz: Cplane-DZ(-)" _
9250. "eamgr: Entity Attributes Manager" _
9251. "extsrf: Modify-Surface-Extend" _
9252. "clipbrd: Screen-To Clipboard" _
9253. "regen: Screen-Regenerate" _
9254. "slccrvs: Create-Point-Slice" _
9255. "slcsrfs: Create-Curve-Slice" _
9256. "catan2: Create-Arc-Tangent-2 Entities" _
9257. "circmill: Toolpaths-Circle Mill" _
9258. "sprlhlx: Create-Spiral/Helix _
9259. "crptgrid: Create-Point-Grid" _
9260. "crptbcir: Create-Point-Bolt Circle" _
9261. "fillet: Create-Fillet-2 Entities" _
9262. "filletc: Create-Fillet-Chain" _
9263. "mcplay: Macro-Playback (Toggle)" _
9264. "mcrec: Macro-Record (Toggle)" _
9265. "mcstop: Macro-Pause (Toggle)" _
9266. "anzsnrms: Analyze-Surfaces-Set Normals" _
9267. "crpolyg: Create-Polygon" _
9268. "clprppt: Create-Line-Perpendicular-Pt" _
9269. "clprpar: Create-Line-Perpendicular-Arc" _
9270. "clplldst: Create-Line-Parallel-Dist/Side"_
9271. "clpllpt: Create-Line-Parallel-Point" _
9272. "clpllar: Create-Line-Parallel-Arc" _
9273. "clbisect: Create-Line-Bisect" _
9274. "catancl: Create-Arc-Tangent-Center Line"_
9275. "undelent: Delete-Undelete-Single" _
9276. "hide: Hide" _
9277. "gridprms: Screen-Grid" _
9278. "catadyn: Create-Arc-Tangent-Dynamic" _
9279. "ramsaver: File-RAMsaver" _
9280. "chgattrs: Screen-Change Attributes" _
9281. "jobsetup: Toolpaths-Job Setup" _
9282. "oplist: Toolpaths-Operations Manager" _
9283. "namview: WCS / View Manager" _
9284. "cnv2arcs: Modify-Convert to Arcs" _
9285. "ccedges: Create-Curve-All Edges" _
9286. "studio: Screen-Surf Disp-Studio" _
9287. "clclose: Create-Line-Closest" _
9288. "autocur: AutoCursor (Toggle)" _
9289. "shadetog: Fulltime Shading (Toggle)" _
9290. "quitop: Delete-Last Operation" _
9291. "editlast: Modify-Last Operation" _
9292. "grnamed: Gview-Named" _
9293. "cpnamed: Cplane-Named" _
9294. "tpnamed: Tplane-Named" _
9295. "multiax: Toolpaths-MultiAxis" _
9296. "curve5ax: Toolpaths-Curve 5 Axis" _
9297. "drill5ax: Toolpaths-Drill 5 Axis" _
9298. "swarf5ax: Toolpaths-Swarf 5 Axis Floor" _
9299. "flow5ax: Toolpaths-Flow 5 Axis" _
9300. "rotary4x: Toolpaths-Rotary 4 Axis" _
9301. "grnormal: Gview-Normal" _
9302. "greqcpln: Gview-Equals Cplane" _
9303. "greqtpln: Gview-Equals Tplane" _
9304. "autodesk: File-Convert-AutoDesk" _
9305. " " _
9306. "dfregen: Draft-Regenerate-All" _
9307. "dfrgsel: Draft-Regenerate-Selected" _
9308. "dfrgaut: Draft-Regenerate-Auto (Toggle)"_
9309. "crdmhz: Create-Dimension-Horizontal" _
9310. "crdmvt: Create-Dimension-Vertical" _
9311. "crdmpll: Create-Dimension-Parallel" _
9312. "crdman: Create-Dimension-Angular" _
9313. "crdmdia: Create-Dimension-Circular" _
9314. "" _
9315. "crdmbsln: Create-Dimension-Baseline" _
9316. "crdmchn: Create-Dimension-Chained" _
9317. "crdmord: Create-Dimension-Ordinate" _
9318. "crdmpt: Create-Dimension-Point" _
9319. "dfvdate: Draft-Regenerate-Validate" _
9320. "sldhist: Create-Solids-History" _
9321. "sldmake: Create-Solids" _
9322. "hidemore: Hide-Hide More" _
9323. "unhdsome: Hide-Unhide Some" _
9324. "makebbox: Create-Bounding Box" _
9325. "setmain: Levels-Main (from entity)" _
9326. "gvbottom: Gview-Bottom" _
9327. "gvback: Gview-Back" _
9328. "gvleft: Gview-Left" _
9329. "***** wire *****" _
9330. "csblend3: Create-Surface-3 Surface Blend"_
9331. "csblendf: Create-Surface-Fillet Blend" _
9332. "csprim: Create-Surface-Primitive" _
9333. "csrfsld: Create-Surface-From Solid" _
9334. "tscurves: Modify-Surface-Trim-To Curves" _
9335. "tsplane: Modify-Surface-Trim-To Plane" _
9336. "tssurfs: Modify-Surface-Trim-To Surfs" _
9337. "tsfbnd: Modify-Surface-Trim-Flat Bndy" _
9338. "tsuntrm: Modify-Surface-Untrim" _
9339. "tsrbnd: Modify-Surface-Remove Bndy" _
9340. "tssplit: Modify-Surface-Split" _
9341. "dragnote: Modify-Drag-Note" _
9342. "dfshow: Draft-Show Assoc" _
9343. "cpbottom: Cplane-Bottom" _
9344. "cpback: Cplane-Back" _
9345. "cpleft: Cplane-Left" _
9346. "cpeqgviw: Cplane-Equals Gview" _
9347. "cpeqtpln: Cplane-Equals Tplane" _
9348. "transtog: Translucent Shading (toggle)" _
9349. "" _
9350. "gvdypan: Gview-Dynamic Pan" _
9351. "gvdyzum: Gview-Dynamic Zoom" _
9352. "attribs: Attributes" _
9353. "anznumbr: Analyze-Number" _
9354. "anzchain: Analyze-Chain" _
9355. "anzckmdl: Analyze-Surfaces-Check Model" _
9356. "anzsmall: Analyze-Surfaces-Small Surfs" _
9357. "anzcksld: Analyze-Surfaces-Check Solid" _
9358. "xfmstrch: Xform-Stretch" _
9359. "xfmroll: Xform-Roll" _
9360. "sldext: Solids-Extrude" _
9361. "sldrev: Solids-Revolve" _
9362. "sldsweep: Solids-Sweep" _
9363. "sldloft: Solids-Loft" _
9364. "sldflt: Solids-Fillet" _
9365. "sldchmfr: Solids-Chamfer" _
9366. "sldshell: Solids-Shell" _
9367. "sldbool: Solids-Boolean" _
9368. "sldprim: Solids-Primitive" _
9369. "slddrfac: Solids-Draft face" _
9370. "sldtrim: Solids-Trim" _
9371. "sldlayot: Solids-Layout" _
9372. "sldfeat: Solids-Find features" _
9373. "sldthick: Solids-Thicken" _
9374. "sldrmfac: Solids-Remove faces" _
