Vb script for drill circle picking
You could use the AskValue() function to prompt the user for a diamter like this:
Dim iDia    ' var to hold diameter value
If Not (askValue("Enter diameter:", 0, 100, iDia)) Then
' user canceled os you can bail if need be
End If
Then you can loop throught the database to find arcs that match what you're looking for:
    Dim bSuccf            ' success flag
Dim arrNewArcs() ' array of arcs
Dim arcTemp ' temporary arc object
Dim iArcCount ' number of arcs
' init
iArcCount = 0
' look for arcs
bSuccf = StartDBSearch(mc_alive, mc_arctype)
' good to go?
If bSuccf Then
Do
' create an arc object for the current arc
Set arcTemp = New McAr
' get the current arc
If GetArcData(GetEntityEptr, arcTemp) Then
' add the arc to the array if it has the diameter we want
If (arcTemp.R * 2 = iDia) Then
' resize the array
ReDim Preserve arrNewArcs(iArcCount + 1)
' add the new arc to our array
Set arrNewArcs(iArcCount) = arcTemp
' increment the counter
iArcCount = iArcCount + 1
End If
End If
' get the next arc
bSuccf = NextDBSearch()
Loop While bSuccf
End If
You would then have an array, called arrNewArcs, containing Mastercam arc objects (McAr) that have the same diameter as what the user entered. From that point, you can do what you need to.
For more examples, look in the VB sub directory in your Mastercam installation directory.
[ 09-24-2004, 01:32 PM: Message edited by: Bullines ]
I would like to use the variable Idia when I get to the Mask on Arc command so I dont need to select an arc from the part. Could I use a script using the Toolpaths - Drill - Mask on arc commands with a prompt for the value of Idia and then using the aray arrNewArcs for creating point positions.
Thanks again.
Bob.
