VBS Dynamic Arrays ???
Why can't I use a dynamic array in VBS? Do I need to test how many elements there will be, then redim the array with the proper size?
This fails, subscript out of range..
Dim a()
Dim b
b = 0
For b = 0 To 3
a(
B)
= b
ShowString a(
B)
Next
This works...
Dim a(3)
Dim b
b = 0
For b = 0 To 3
a(
B)
= b
ShowString a(
B)
Next
Ahh, lernt a new option, Preserve... TY.
One more thing, O/T from this, but related in my own little world... Is there a way, outside VBS, to temporarilly over-ride the NCI destination?.
I have a file with 6 Groups, totalling 53 Ops. Each group has a different NCI destination. I want to be able to post them all to a single NCI, but not lose the original destinations. Possible? Or will I be writing a script for that?? wink.gif
'Rekd
What a coinkydink wink.gif I'm working on a C-Hook to do the exact same thing. I'd like to add to your question, Rekd, if you don't mind. Anyone know how to suppress the NC and NCI file location/overwrite prompts when posting using nci_manager() with the NCIMGR_POST_ONE flag?
Bullines,
Look at postOps() in m_nc.h and post_dlg_settings in m_ncvars.h. It should do some of what you want. I for banghead.gif for the life of me can't banghead.gif get them to work right. Things like the nc extension overide variable in the post don't set right plus some other stuff I can't remember off the top of my head right now. I eventually gave up trying to get it to work and turned my attentions to more productive projects. Maybe you can have better luck.
Thanks for the tip Bryan cheers.gif Unfortunately, it still prompts for NC/NCI file locations and overwriting mad.gif Hmmmm confused.gif
// my settings
post_dlg_settings my_settings;
// init the members of the post_dlg_settings structure
my_settings.save_nci_file = TRUE;
my_settings.overwrite_nci = TRUE;
my_settings.save_nc_file = TRUE;
my_settings.overwrite_nc = TRUE;
my_settings.send_to_machine = FALSE;
my_settings.editNCI = FALSE;
my_settings.editNC = FALSE;
my_settings.export_oplist = TRUE;
my_settings.export_prm = TRUE;
my_settings.wcs_1014 = FALSE;
my_settings.descriptor = TRUE;
// post it up
postOps(&my_settings, "mpmaster.pst", nc_prefix, FALSE, FALSE);
I spoke a little too soon. It seems that postOps posts all operations.
// get the head of the operations linked list
list_manager(OP_ID, "", LSTMGR_GET, &op_ptr);
while(op_ptr)
// get the operation
operation_manager(&(op_ptr->op), OPMGR_GET, &ent_ptr, &bSuccf);
// next operation
op_ptr = op_ptr->next_ptr;
In the while loop, I call postOps and I plan to grab the NCI filename of each operation during each iteration of the while loop from the nci_filename variable. This works if you use NCIMGR_POST_ONE with nci_manager() but not now, since nci_filename is still holding the filename of the first operation frown.gif
I am whining here
NO
But I do like to see CNC Software release a new documentation of the chook library. It really needs an update!
+1000000000
With some real world examples. Add points to drill, add chain to contour, create surfs, import ops, import tools, create tools, POST, yada yada yada. Everything you'd probably do on a day to day basis but with a chook. That way it could be done better with a chook or at least automate the steps to make it faster.
Bryan smile.gif teh fustrated.
