VBS: Reusing code
In languages like C++, Pascal, Java, etc., it's simple to reuse code. C/C++ has the #include directive, Pascal has the uses keyword and Java has the import keyword. If you have code that you find yourself copying and pasting into your scripts over and over, include 'em smile.gif I know of three ways to do it from VBS, but only 2 of them seem to work with Mastercam, and it's still a little bit tricky.
If you have code that doesn't use any Mastercam functions such as file I/O stuff or whatever, you can use WSC (Windows Script Component). WSCs are like C/C++ header files but require a specific syntax that'll look weird at first. You can use the WSC Wizard to create the skeleton of WSC files for you. Here's a little script, let's call it VBMsg.wsc that simply prints out a message using VB's MsgBox() function:
<?xml version="1.0"?>
<component>
<?component error="true" debug="true"?>
<public>
<property name="message">
<get/>
<put/>
</property>
<method name="display">
</method>
</public>
<script language="VBScript">
<![CDATA[
Dim strMessage ' the global message
' Purpose: retrieve what's currently in the global message variable
' I: (nothing)
' O: the value of the global message variable
Function get_message()
get_message = message
End Function
' Purpose: sets the value of the global message variable
' I: new value for the global message
' O: (nothing)
Function put_message(strNewMessage)
strMessage = strNewMessage
End Function
' Purpose: displays the global message
' I: (nothing)
' O: (nothing)
Function display()
MsgBox strMessage
End Function
</script>
</component>
Now from our Mastercam script, say Test1.vbs, we can do the following:
' -- Start Script
Call Main()
' Purpose: the main sub routine
Sub Main()
Dim objTestInclude ' object from our WSC file
' get a reference to the WSC
Set objTestInclude = GetObject("script:C:FullPathToVBMsg.wsc")
' set the message var
objTestInclude.message = "Yo, from me!"
' run the function that displays the message var
objTestInclude.display
' clean up
Set objTestInclude = Nothing
End Sub
I haven't found a way to run Mastercam VBS functions from WSC yet. In that case, you can create your own include function that uses the ExecuteGlobal statement. Let's say I have a file called BullinesArc.txt that contains code to simply create an arc at origin with a diameter of 4:
' Purpose: creates an arc at origin with a diamter of 4
' I: (nothing)
Sub BullinesCreateArc()
Dim nRet ' return value of CreateArc()
Dim arcTheArc ' the new arc
' get a reference to a Mastercam arc object
Set arcTheArc = New McAr
' set the parameters of th earc
arcTheArc.X = 0
arcTheArc.Y = 0
arcTheArc.Z = 0
arcTheArc.R = 2
arcTheArc.SA = 0
arcTheArc.SW = 360
' create the new arc
nRet = CreateArc(arcTheArc, mcCONSTRUCTION_COLOR_CURRENT, mcCONSTRUCTION_LEVEL_CURRENT)
' clean up
Set arcTheArc = Nothing
End Sub
Then call our Include() sub routine as soon as we enter our Mastercam script, Test2.vbs so that we can use the function in BullinesArc.txt:
' -- Start Script
Call Main()
' Purpose: Include code from an external file
' I: full path to the file to be included
' O: (nothing)
Sub Include(FilePath)
Const ForReading = 1, TristateUseDefault = -2, DoNotCreateFile = False ' just like in VB
Dim objFSO ' FileSystem object
Dim objCurrFile ' File object
' get a reference to the objFSO
Set objFSO = CreateObject("Scripting.FileSystemObject")
If (objFSO.FileExists(FilePath)) Then ' the include file is there
If (objFSO.GetFile(FilePath).Size > 0) Then ' the include file actually has something in it
' get a reference to the file object using the include file
Set objCurrFile = objFSO.OpenTextFile(FilePath, ForReading, False, TristateUseDefault)
' allow our imported code to run
ExecuteGlobal(objCurrFile.ReadAll): objCurrFile.Close
End If
End If
' clean up
Set objFSO = Nothing
Set objCurrFile = Nothing
End Sub
' Purpose: the main function
Sub Main()
' include the file
Include("C:FullPathToBullinesArc.txt")
' call BullinesCreateArc() from the included file
Call BullinesCreateArc()
End Sub
