Chook - Dialog Box Manager Sample
I am trying to run the sample from the Chook SDK on chapter 22 page 19-24.
I had copy the scr file, create the sample.c file and also the sample.txt file.
I am running Win2000, MC 9.1 SP2, MS-VC 6.0.
When I execute the sample.dll chook, I got two errors:
a) DBM Alert: Invalid control type
B) DBM Alert: Internal fatal error... cannot run dialog.
The SDK scr file says it's a Version 7.0 scrversion. Do I need to change anything in the script file?
Did anybody try this sample dialog before?
What did I do wrong here?
Please help. Thanks
Bryan,
I can compile the shapes example but I couldn't execute it in MasterCAM.
It always said program entry not found no matter what I change in my settings.
I am using VC++ 6.0. Can you show me what you did?
I can write program in plain C without any MFC linking. When I have my file in .cpp, I cannot make it work. Which is the reason I wanna try the dbm from the chook library.
also, sometime MC will say incompatible script version when execute the chook w/dbm. Anybody knows what should be done?
I've wanted to create a dialog box for one of my C-Hooks but can't ever seem to get it. Is there a sample I'm missing in the SDK? MFC, DBM, etc... don't really care which, just want to learn it.
James,
There's a sample from the Chook SDK on chapter 22 page 19-24 that shows you how to create a chook dialog without any MFC. However, I haven't make it to work. Hope you get a better luck than me.
You can always create your own C++ dialog in MFC too. The first chapter of the SDK shows a pretty good example. Again, I am just not smart enough to make it work.
Please let me know if you can make both sample work.
...I am just not smart enough to make it work...
I'm in that boat right now so I guess I'm in good company. wink.gifbiggrin.giftongue.gif
Guess I'll just have to keep trying, then again, I've put less than a half-hearted effort into it so what should I expect? rolleyes.gif
Bryan,
I just used them to start a new mfc/c++/chook project and they worked fine.
Did you change anything to make it work?
I did exactly what Bulliness said and I still get that anoying Fatal Error: Program Entry Not found error.
The only thing that I change is commented out the #UNDEF export line. If I have those lines, I will have three compiler errors.
Please help. Thanks
program entry not found sounds like your missing the
 extern "C" void CH_ENTRY m_main (long *ptrs)
if (open_app (ptrs))
if (product_level_1_or_design_enabled())
AFX_MANAGE_STATE(AfxGetStaticModuleState());
/* put your function here */
your_function();
close_app (ptrs);
Sounds like MC is looking for the m_main and can't find it.
if (open_app (ptrs)) // open interface to Mastercam
// Enable use of the MFC dynamically linked libraries
// call our main function
main_whatever();
close_app (ptrs); // close interface to Mastercam
I do have these lines of code and it still gimme the same error message.
Any clue? Thanks
I got the following message when I compile my program.
--------------------Configuration: whatever - Win32 Release--------------------
Compiling resources...
Compiling...
StdAfx.cpp
Compiling...
whatever.cpp
WhateverDlg.cpp
Generating Code...
Linking...
Creating library Release/whatever.lib and object Release/whatever.exp
whatever.dll - 0 error(s), 0 warning(s)
Am I suppose to see some kind of message indicating that the two critical object file have been link to the project?
How can I be sure that those two files have been compiled?
Do I need to change any setting in the link tab of the project setting?
Please help. Thanks
During compilation/linking, you won't see that the DLL is linked to the OBJ files. As long as the OBJ files are part of the project, you'll be fine:
  • 1 year later...
OK thanks, but it seems like the samples have not been included in the new chm file. Maybe the Chdocs9 would be useful to me. Unfortunately I don't have SDK version 9. I tried www.mastercamextranet.com and www.mastercam.com, but couldn't find it.
Therefore, would someone please give me advice, where I could find SDK 9 or upload it to ftp.mastercam.com?
