unhandled exception with a chook
the main problem, is that the error appears when get_levname function
Are you certain that you allowed enough room for a '0' in the string name? It could be that the max_size parameter is too small for the level name. For example:
char szSomeCharArray[7] = "Testing";  // bad
char szSomeCharArray[8] = "Testing"; // good
Here's a slight modification of Bullines' code. It's not too pretty but compiles and runs fine on my machine. It prints the name level or error to mastercams prompt areas. See if this works any better.
boolean succ;
short num_level = 1;
char Name_level[600];
succ = get_levname(num_level,599,Name_level);
if (succ == TRUE){
cleartextall();
mprintf("Successn");
mprintf("levelname:%sn",Name_level);
wait_for_space();
else
cleartextall();
mprintf("Something went wrongn");
wait_for_space();
it runs fine also
you know the oly difference between my code and your's is that i declared "char *Name_level" and u have declared an array!
in m_io.h, they said
EXTERN boolean (*_get_levname) (
short lev_num, /* I: level number */
short max_size, /* I: size of string */
char *level_name); /* O: level name (max of 'max_size' characters) */
#define get_levname (*_get_levname)
I don't understand why they (mastercam programmers) need to know the size of the level name if the same time they ask for an array!!?
thnk u very much
With malloc we need to know the memory space to allocate
malloc(), on most platforms, takes only one parameter; the number of bytes to reserve. But this is besides the point wink.gif
No, Sorry itsn't the same thing.
With malloc we need to know the memory space to allocate dynamically, but here when we declare an array (staticaly) we know in advance the space needed!
So the max_size in get_levname function will be unused
You missed what I meant wink.gif I meant that the malloc() or memset() is likely called in Mastercam after a C-Hook developer, such as yourself, passes a var like max_size to a C-Hook function. Mastercam, in turn, probably uses malloc() or memset() internally.
get_levname() is expecting that the programmer has declared the string size himself, i.e.
char lName[200];
or
char *lName = (char *)malloc(200, sizeof(char));
before calling the function. We will put the name in the memory that you provide. Passing the 'size' of the string ensures that we don't try to fill beyond the true length of the array
PDG
