VBS Create Folder Method
I have figured out how to create a single folder using VBS, but how do you create a subfolder whose parent folder doesn't exist yet. Do you first have to create the parent folder then the subfolder? We backup our files onto our network and somtimes the folders get nested up to five or six times. What I am trying to do is create a vbs that will save the file to my hard drive first and then duplicate the file path to save it on the network. I have successfully done this so far, but the network path has to already be there. ie if my hard drive path is c:camgmpt4t65ejectorrev_gz my network path would be k:camgmpt4t65ejectorrev_gz. I have been able to have the script tell me if the folder exists or not. I would like to be able to have it create the folder if it does not exist. I think the CreateFolder Method only allows you to create one folder at a time, but I'm not sure.
McamX MR1
Win XP
thoskins,
The FSO model doesn't have a method to create nested folders.
I cannot take credit for this function, but it worked for me...
Say that "c:temp" already exists, and you want a new folder that is several levels deeper
Call it with your desired folder, like this -->
CreateDirectory("c:temptestsubfolder1subfolder2")
Function CreateDirectory(dirName)
Dim aFolders, newFolder
Dim delim
Dim fso
Dim i
Set fso = CreateObject("Scripting.FileSystemObject")
' Checks the folder's existence.
If Not fso.FolderExists(dirName) Then
' Splits the various components of the folder name.
If instr(dirname,"") Then
'Set up this delimiter to handle UNC paths
delim = "
-_-
_-_-"
dirname = replace(dirname,"",delim)
End If
aFolders = split(dirName, "")
If InStr(dirname,delim) Then
dirname = replace(aFolders(0),delim,"")
End If
' Obtains the drive's root folder.
newFolder = fso.BuildPath(dirname, "")
' Scans each component in the array, and create the appropriate folder.
For i=1 To Ubound(aFolders)
newFolder = fso.BuildPath(newFolder, aFolders(i))
If Not fso.FolderExists(newFolder) Then
fso.CreateFolder newFolder
err.clear
End If
Next
End If
End Function
Here it is, my first useful script. It saves your currrent file to its original location and backs it up to a secondary location by changing the drive letter to whatever you like.
Code:
'// Author: Tim Hoskins with help from Roger Martin
'// Date: 04/08/2006
'// File Name: Saves file to current location and a secondary location
'// Description: Mastercam VB Script
'// Comments: It ain't pretty, but it works
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
On Error Resume Next
Dim strBackupPath
Dim strOriginalPath, funame
Dim fname, fkname, show
Dim ndir, SearchChar, SearchString
Dim path, flength, npath
Dim newpath, MyPos, npathh
Dim pathnew
pathnew = "K:TOSHIBA_200" 'Prefix of the Secondary path to save file to
strOriginalPath = GetCurrentFileName 'Gets the name of the current Mastercam file
SearchString = strOriginalPath 'Stores the current name for other use
SearchChar = ""
MyPos = InstrRev(SearchString, SearchChar, -1, 1) 'Searches current file name for first instance of the search character and returns location its location in the string
flength = MyPos - 1
npath = left(SearchString, flength) 'Sets the variable to name of the folder on the hard drive
npathh = Mid(npath, 3, 200) 'Sets variable equal to the path minus the drive designation
newpath = pathnew + npathh 'Assembles the Secondary path
Call CreateDirectory(newpath) 'Calls the function to create the new Directory
fname = Mid(strOriginalPath, 3, 200) 'Gets filename minus drive designation
funame = Ucase(fname) 'Changes the case of name
fkname = Ucase(pathnew + funame) 'Assembles new file name
Call SaveMC(true) 'Saves the current file with the original name
Call SaveMCAs(fkname, true) 'Saves the file with the new filename
show = Ucase("FILE SAVED AS" + vbcr + strOriginalPath + vbCr + "AND" + vbCr + fkname)
ShowString(show)
End Sub
Dim delim
Dim fso
Dim i
delim = "-_-_-_-"
End If
End If
err.clear
End If
Next
End If
End Function
