X C-hook/NETHook generate NCI files
Hello all,
I am a newbie to C-Hooks, I read through the documentation but I could not find information on how to generate NCI files through C-Hook. I would like to generate this myself so I could add some additional information there for customization.
Any information pointers or sample code is helpful. I would prefer NET Hook code and if not C-hook.
Regards,
Surya.
For chooks postOps function will generate an nci file. It'd look something like this:
    post_dlg_settings ps;
/* create and save nci */
ps.save_nci_file = TRUE;
ps.overwrite_nci = TRUE;
ps.editNCI = FALSE;
/* don't create nc */
ps.save_nc_file = FALSE;
ps.overwrite_nc = FALSE;
ps.editNC = FALSE;
ps.send_to_machine = FALSE;
ps.export_oplist = TRUE;
ps.export_prm = TRUE;
ps.wcs_1014 = FALSE;
ps.descriptor = FALSE;
/* generate nci files */
postOps( &ps,
postprocessor,
destinationdir,
FALSE, /* CALL POST DIALOG */
FALSE); /* DISABLE POST BUTTON */
You can later call the run_post_exe_dll function to run it through a post processor.
  • 2 months later...
I found that postOps works only if the operation has been selected. The question now is how do I select an operation from a C-hook (operation_manager with OPMGR_GET does not seem to do the trick)?
Marko
[ 07-26-2006, 08:55 PM: Message edited by: markov ]
One more thing I have noticed. Try running the following simple C-hook under debugger:
extern "C" __declspec(dllexport) int m_main(int not_used) {
post_dlg_settings p;
p.save_nci_file = TRUE;
p.overwrite_nci = TRUE;
p.editNCI = FALSE;
p.save_nc_file = TRUE;
p.overwrite_nc = TRUE;
p.editNC = FALSE;
p.send_to_machine = FALSE;
p.export_oplist = FALSE;
p.export_prm = FALSE;
p.descriptor = FALSE;
p.wcs_1014 = FALSE;
MessageBox(NULL, "Checkpoint 1", "CHookTest", MB_OK);
char t1[FILENAME_MAX] = "C:mcamxmillpostsMPFAN.PST", t2[FILENAME_MAX] = "C:mcamxmillnc";
postOps(&p, t1, t2, TRUE, FALSE);
MessageBox(NULL, "Checkpoint 2", "CHookTest", MB_OK);
return MC_NOERROR | MC_UNLOADAPP;
It reports some kind of heap corruption, although the release version executes apparently OK. Should I be concerned (I think I should)?
Marko
Let me answer the first question myself. Maybe there is a beter way, but I have found the following can select the operation:
operation_manager(&current_op, OPMGR_GET, &o_ptr, &s);
current_op.db.select_flag = TRUE;
operation_manager(&current_op, OPMGR_REWRITE, &o_ptr, &s);
Marko
something like this will set all unselected operations to selected. I don't have my notes but for some reason I had to call operation_manager to force update something in the operation manager.
op_list *opl;
opl = op_list_ptr;
while (opl != NULL)
if (opl->op.db.select_flag == FALSE)
MC_BOOL succf = FALSE;
DB_LIST_ENT_PTR eptr;
opl->op.db.select_flag = TRUE;
operation_manager( &opl->op, OPMGR_REWRITE, &eptr, &succf);
/* next operation */
opl = opl->next_ptr;
