Hello.
I'm writing v9 chook now
and trying to add drive surface to new operation.
all surfaces are selected with SELECT_BIT.
but when I called code below,
selected surfaces are added as check surface...not drive surf... confused.gif
any idea?
Thank you
	surface_manager (
op.op_idn, // I: operation id to edit
&chains, // IO: ptr to list of chains if using SRFMGR_CHN_***
SRFMGR_SRF_ADD, // I: what you want to do
1, // I: 0=drive & check, 1=drive, 2=check
&succf); // O: TRUE = everything went ok
(Instead, I'm using SRFMGR_SRF_SEL&&sending key event to main window.. mmmmm)
Never used the function myself. I'm assuming you already tried calling with 0 or 2 instead of one.
0=drive & check looks like you can designate a surf as check or drive. So shooting in the dark try flipping other sel bits. I'd try
#define TEMP_BIT 0x40 /* bit 6 */
first.
  • 3 months later...
MasterShake (or anybody else),
what is CHAIN **chns argument in the surface_manager function? In my case I have got the operation and the trimmed surface, so what do I pass? The comment next to the argument leads me to believe that I should pass chains only if I am using one of the SRFMGR_CHN_* "modes", but what to use with SRFMGR_SRF_ values?
hello
I think CHAIN **chns argument is boundary chain.
when you add a chain to operation ,try SRFMGR_CHN_ADD.
adding a surface to an operation...
//set SELECT_BIT or select by select_ents
e.id=SURF_ID;
store_ent (&e, &e_ptr, ALIVE_BIT, main_color, main_level, main_attrib, &succf);
sel_bit_turn_on (&e, SELECT_BIT);
rewrite_ent(&e);
surface_manager (
NULL, // IO: ptr to list of chains if using SRFMGR_CHN_***
No, it does not work for me. Here is the complete source, I ran it on the geometry with couple of surfaces and one operation already set up. The surface is not added to the operation after the C-hook executes.
extern "C" __declspec(dllexport) int m_main(int not_used) {
DB_LIST_ENT_PTR eptr;
MC_BOOL succf;
p_2d sel_pt;
double t[2];
ent srf;
select_ent("Select surface",//LPCTSTR cs,
&srf, //ent * entity,
&eptr,//DB_LIST_ENT_PTR * eptr,
sel_pt,
t,
ALIVE_BIT,//short smask,
SURF_ID,//long emask,
RED,//int s_color,
&succf
if (succf)
MessageBox (NULL, "Selected", "Test", MB_OK);
op_list *op_head = 0;
list_manager(OP_ID, "", LSTMGR_GET, (void**)&op_head);
if (!op_head || op_head->next_ptr) {
MessageBox (NULL, "No or more that one operations", "Test", MB_OK);
return MC_NOERROR | MC_UNLOADAPP;
surface_manager (
op_head->op.op_idn, // I: operation id to edit
MessageBox (NULL, succf? "Add OK": "Add failed", "Test", MB_OK);
it seems that select_ent does not set SELECT_BIT..
if (succf)
sel_bit_turn_on (&srf, SELECT_BIT);
rewrite_ent(&srf);
operation op;
operation_manager(&op, OPMGR_GET_FIRST_LIST, &eptr, &succf);
surface_manager (
or use SRFMGR_SRF_SEL
MC_BOOL succf;
operation op;
surface_manager (
SRFMGR_SRF_SEL, // I: what you want to do
  • 1 month later...
Let's add a couple of calls to the above program:
chain_1("Boundaries",  &chains);
surface_manager(op_head->op.op_idn, &chains, SRFMGR_CHN_ADD, 0, &succf);
When the C-hook terminates, I only see the surface in the operation manager, and not the boundary. But there is something even more interesting: if I save the MCX file, and reload it again, I can see both the surface and the chain in the operation manager.
This means that I need somehow to refresh the content of the operation manager, but I do not know how. Any ideas?
Marko
I thought SRFMGR_CHN_ADD is to add the bounday chain.. but it seems not...
chain manager worked for me anyway.
	chain_manager_info cmi;
memset (&cmi, 0, sizeof (chain_manager_info));
cmi.op_idn = op.op_idn;
cmi.mode = CHNMGR_ADD;
chain_manager (&cmi, TP_CHN_TCB, &succf);
SRFMGR_CHN_ADD may be used for adding swarf toolpath chain or something... just a guess
extern DllImpExp group_list * OMrefreshGroup(long a0,char a1);
extern DllImpExp int OMrefreshOpManTree(void);
extern DllImpExp op_list * OMrefreshOperation(long a0,char a1);
Hi MasterShake,
I'm interested in those functions.
In which header are those functions written?
I wasn't able to find those...
Kaoru Naruse
MasterShake,
OMrefreshOpManTree did not work, and the same applies to OMrefreshOperation, although I passed 0 for the second argument, not knowing a better value. I did not try the third refresh function.
Your chain_manager trick does work, but it does not apply to my case. In the sample code I presented here I used chain_1 function, but that is just for the sake of question simplicity. In the reality, I am building the chain myself from within the C-hook, so I need to know how to add an already defined chain as a boundary to the surface operation.
Marko
