Creating tool paths with nethook
Hello all,
I have been exploring the use of nethooks using visual basic to automate some of our common functions. Currently it looks fairly simple to automate functions such as creating geometries and setting gui parameters and such. The thing I can't figure out, however, is how I would create the various milling tool paths using selected geometry and tools from our library. For example: I would like to select all features on a given layer and then create a pocketing tool path for all the features (assuming they are all closed chains), using 1/4 endmill from alum6061 library.
Is something like this possible using a vb nethook? If so, are there any examples or white papers that could get me started? I'm using visual studio 2005 standard for development.
Thanks very much,
David
I dont happen to have a VB sample but here is a C# example that should be easy enough to convert over to VB. Feel free to post questions to this thread.
//Create a pointer to our saved route operation
// operations == fullpath to your *.operations file opId == the op id of the operation you want to use
Mastercam.COperationRef opRef = COperationRef.ImportFromFile(operations, opId);
//Does operation exisit in the operations file?
if ( opRef == null )
throw new Exception("RouteLevel::COperationRef.ImportFromFile(" + operations + "," + opId.ToString() + ") not found!!!");
//Store original toolside
CutterCompType originalComp = opRef.CutterComp;
//Do we need to reverse the chain to set the correct toolside?
bool reverseChain = ( ConventionalRoute && ( originalComp == CutterCompType.CutterCompLeft ) )
|| ( !ConventionalRoute && ( originalComp == CutterCompType.CutterCompRight ) );
ArrayList chainrefs = new ArrayList();
//Chain all on this level
if ( !Mastercam.Chain.ChainAll(true, true, thisLevel, true, chainrefs) )
throw new Exception("Call to RouteLevel::ChainAll failed on level " + thisLevel + "!!!");
else
if ( Chain.ChainManager(opRef, chainrefs, 1, 0) )
if ( reverseChain )
foreach ( CChainRef cr in chainrefs )
if ( !Chain.ReverseChain(cr) )
throw new Exception("Call to RouteLevel::Chain.ReverseChain() failed on level " + thisLevel + "!!!");
if ( !Toolpath.RegenOp(opRef) )
throw new Exception("Call to RouteLevel::RegenOp() on level " + thisLevel + " failed!!!");
else
throw new Exception("Call to RouteLevel::Chain.ChainManager() on level " + thisLevel + " failed!!!");
if ( chainrefs.Count > 0 )
if ( !Mastercam.Chain.FreeChains(chainrefs) )
throw new Exception("Call to RouteLevel::FreeChains() on level " + thisLevel + " failed!!!");
This was a really nice and helpful example.
I tried to use it to make a lathe operation. After a day of trying and retrying I managed to produce this:
string pathMC = Mastercam.GUI.GetMCRootDir();
string pathAL = String.Concat(pathMC, "chooksAutolathe");
string operations = String.Concat (pathAL, "AUTOLATHE.OPERATIONS");
string opId = "OD_ROUGH_R";
This code works only after I have already created (and deleted) a lathe operation in Operation Manager. If I start with a new file, I get the exception message: "Attempted to read or write protected memory. This is often an indication that other memory is corrupt." Nevertheless, the operation is created.
Please, help me further in creating a lathe operation and defining its parameters in C#.
Thank you very much.
Now I have succesfully added these more lines from the Mick's code from the first reply of this Topic:
The next lines are:
bool reverseChain = ( ConventionalRoute && ( originalComp == CutterCompType.CutterCompLeft ) ) || ( !ConventionalRoute && ( originalComp == CutterCompType.CutterCompRight ) );
I roughly understand the meaning of these lines, but I don't understand how this code works. Therefore, please explain the term: "ConventionalRoute".
Thank you.
  • 1 month later...
