Operations & nethooken
Anyone know how to reference individual operations using a nethook?
they have a coperationref class, but I dont know how to set it equal to an existing operation.
what would be ideal.... is to have the operations grouped as a collection.
then have each operation referenced as an "item"
so then you could get the operationgroupcount
like is there
then just loop through the operation collection
replacint the item numbers 0 - etc....
or it could go
I'll abbreviate a little
dim machinegroupcount As Integer
machinegroupcount = mcam.tpath.getmachinegroupcnt
then
dim machinegroupA As machinegroup
machinegroupA = mcam.tpath.getmachinegroup(i)
dim opgroupcount As Integer
opgroupcount = machinegroupA.getopgroupcount
dim opgroupA As opgroup
opgroupA = machinegroupA.getopgroup(i)
dim opA As COperationRef
opA = opgroupA.getop(i)
etc..etc....
Below is some code I was using to test out some stuff, it might be useful.
try
int groupCount = Groups.GetGroupCount();
for (int grp = 1; grp <= groupCount; grp++)
string grpName = Groups.GetGroupNameFromNumber(grp);
if (grpName != null)
if (Groups.IsMachineGroup(grpName))
string next = Groups.GetNextGroup(grpName);
else if (Groups.IsToolpathGroup(grpName))
if (grpName == "Nesting Results")
else
catch (Exception ex)
finally
mmmmmmmm......
I can get group names and group numbers.
but to actually set my operationref class to the operation itself.
operationref = mastercam.?.?
how do we go about doing that?
cus we dont have a groups.getnextgroup function
orrrrrr wait a minute.......
issss it. COperation = New then use the grpName?
nope that wattin it.
hm. well. I dont know.
looking through the object browser I just really can't see anything that'd do it.
cus even if you wanted to create a new coperationref using an existing coperationref
like as one of the overrided options would supposively accept.
How the hecks would ya reference one to even put in there for it to copy????
this thing is sooooo close yet so far away.
well I'm tired. hitter again tomorrow.
ya know. and really. we should be able to access all of mastercams functionality just as we're able to access the functionality of our own forms and functions.
I was going to start out and develop a "flymode" for X but we're not really able to set a new view like how a user could.
in all technicality. I should be able to create an axis. then set a view using my x line and the z line that would be created in the nethook.
then just move the axis continuously.
during refresh re-associate the X and Z lines.
mm mm. sounded like a good idea.
smile.gif I've been fightin the get filename for a while now.
if it were as simple as mcfile.getcurrentfilename()
this'd be a done deal.
the only members I have under mcfile is
EditFile
NewMC
SetFileUnchanged
DoBitmapFile
DoFileOpen
DoFileOpen
DoMetaFile
GetPathFromExt
GetPathOfThisScript
ImportFile
OpenMC
ReadDXF
SaveMC
SaveMCAs
WriteDXF
which most require a complete filename
which if to be useful would need some way of getting the current filename.
but there's nothing about the actual filename itself??
which we could get tricky and search to the current directory, and search through the files for the most recent.
But for 1 we're risking a system lockup
2) we wouldn't be for sure if the most recent file saved is actually the file that made the nethook call.
And for getting the operations there's no
getoperations member. even under tool path
all I have for toolpath is:
EditTool
RunPointManager
SetBlockDrillLibrary
SetPostName
SetToolLibraryName
DoNest
EditOperationGeometry
EditOperationParameters
GetBlockDrillLibraryName
GetJobSetupMaterial
GerJobSetupStockOriginX Y and Z
GerJobSetupStockSizeX Y and Z
GetNestedSheetCount
GetOperationCount
GetPostName
GetToolLibraryName
MakeNestedSheetBMP
RegenOp
Nothing about getting an actual tool op.
Which most of these members require a referenced tool op ref... ya know, itslike we have a system of equations trying to solve for 2 unknowns.
shouldn't be that complicated.
Under groups there should be a member that refers to the machine groups.
then under toolpath there'd be a member for getting the ops from the machine group.
just as there is a way to get a tool from an op.
because under the groups all we have are ways of getting name from number
number from name which if the user changes names
we really wouldn't have a way of distinguishing one type of group from another, only by group type. but now you're going to have more if then checks that wouldn't be necessary.
if there was just a separate member for the different kind of groups.
In alllll honosty. These nethooks are almost useless. because thus far. all the functionality could be done by just making an MCX file that has already created geometry and what not and just merge and stuff.
We really dont have much control over modification. which is what we really desire.
Because then we could use the power of associativity and really do some neat stuff.
The only other option I guess is to abandon the nethook approach go back to C-Hooks
But thats old technology.
And actually proves that internally. X is no different than it was 10 years ago.
Under groups all I have is
deletegroupfromname
deletegroupfromnumber
addenttogroup
creategroupfromname
getgroupcount
getgroupname fromnumber
getgrouptype fromname
getgrouptype fromnumber
removeentfromgroup
setgroupname
there really outa be
getentgroup(byval integer)
getmachinegroup(byval integer)
separated like that or something
