Hello all. I think I'm making a newbie mistake. I'm trying to use the DoFileOpen function to open up a mastercam X file. I'm reading the help on it in Core/MFile_CH.h. It says that the variable it calls "filen" "MUST be complete path to file". So I wrote this:
LPCTSTR filen = "C:Program Filesmcamxchook_testsOpen_FileIGES_1.mcx";
Then in main I wrote this:
DoFileOpen(filen, merge, astext, checkUnits);
While debugging it says there's a bad pointer:
filen 0xcccccccc const char *
As I said, I think I'm making a stupid newbie mistake. After searching online for uses of LPCTSTR, I just got more confused. Any help is appreciated. Thanks in advance.
You didn't allocate memory for your string. LPCTSTR refers to a string on the heap (dynamically allocated memory), so such assignment/allocation isn't going to work. The string type you've chosen isn't the best for what you're doing.
There's quite a few ways to allocate a string, for instance:
char s[] = "yadayadayada";  //simple ASCII
TCHAR s1[] = _T("string"); //handles UNICODE too
char * st = new char[10];
strcpy(st, "yelp!"); //deprecated
string tempString; //stl::string
tempString = "temp"; //allows assignment
CString mfcString = "Microsoft uses these";
try something more like:
char filen[] = "C:yadayadayada.mcx"[/indent]
or
[indent]code:
TCHAR filen[] = _T("c:...");
[/indent]
which would put it on the stack instead (handling allocation for you)
or even (cutting a step)
[indent]code:
DoFileOpen("C:yadafile.txt", /*more arguments*/);
[/indent]
cutting the entire allocation problem altogether.
Remember also, you may need to double up on the char, because it's used as an escape character. E.g. "C:mcamxchooksmychook.dll"
Here's a link to a more complete tutorial on the subject:
Tutorial
Here's a decent primer on the std::string class, which is what you want to end up using. It's far more powerfull than a simple character array:
String Class
Pay particular attention to these two entries:
/*Character array to string*/ s = ch; //Converts character array ch into string s.
/*String to character array*/ cp = s.c_str(); //Pointer cp points to a character array with the same characters as s.
Conversion comes up a lot, and typecasting isn't always the best idea when using these
what you'd end up with is code like this:
#include <string>
using namespace std;
//... skipping stuff...
string filen = "C:mcamxdirfile.mcx";
DoFileOpen(filen.c_str(), /*args*/);
Thanks for tutorial on the string class. I'll read through that to figure out it's benefits. I was able to open up the file that I wanted using DoFileOpen, with simply:
char filen[]= "C:Program Filesmcamxchook_testsOpen_FileIGES_1.mcx";
It's great info, and I'm sure I'll need the more robus string class at some point soon.
