Proper way to call subs with Mpmaster V9 post?
I have written a few custom drill cycles to post common G13 routines as subs, but if I translate the part program for multiple work offsets i get garbage posted. I think the problem is how I am calling the custom cycle as a sub.
In pdrlcst :
if drillcyc = 9, # G13 - Standard Feedthru
psub_call_s
subout = 1
psub_st_s
pbld, n, "G0", *feed_hgt, e
pbld, n, "G1", *depth_1, *plunge_fr, e
pbld, n, "G13", *rad_1, *rough_fr, *comp_1, e # solder well depth
pbld, n, "G1", *depth_2, *plunge_fr, e
pbld, n, "G13", *rad_2, *rough_fr, *comp_2, e # roughing depth
pbld, n, "G1", *depth_3, *plunge_fr, e
pbld, n, "G13", *rad_2, *rough_fr, *comp_2, e # rough at finish depth
pbld, n, "G13", *rad_3, *finish_fr, *comp_2, e # finish feedthru diameter
pbld, n, "G13", *rad_3, *finish_fr, *comp_2, e # spring pass
pbld, n, "G1", *depth_1, *rapid_fr, e
pbld, n, "G13", *rad_1, *finish_fr, *comp_1, e # cut burr at solder well depth
pbld, n,"G0", *clear_hgt, e
psub_end_s
subout = 0
In pdrlcst_2 :
#if drillcyc = 9, # G13 - Standard Feedthru Additional Points
if drillcyc > 8, # G13 - Additional Points
sub_prg_call = sub_prg_no
pcan1, pbld, n, pxout, pyout, strcantext, e
pbld, n, "M98", *sub_prg_call, e
Should I put subout = 1 in psub_st_s
and subuot = 0 in psub_end_s for starters?
How do I pass my last sub # to use in auto sub suuport(translate by toolplane)?
I gave up on "being compatible" with mcam auto sub support.
I coded the post to do toolpath subs + custom drill subs nested in lower level. Much easier if I code it myself. mi triggers control tool subs and custom drill subs. Working very well and much cleaner than mcam auto subs.
Guess I didn't need help after all.
How do I disable those subprogram check boxes anyway? LOL
